about 1200 miles on rebuild, bored, pistons, bearings, valve job, etc
going down the interstate about 70 mph and engine starts making loud noise as if a small screw or washer got sucked into a cylinder.
the noise slowly got quieter as if what ever was in there got pounded into the piston.
got it home and had a loud tick as if a lifter collapsed, but it was in time with the valve train and not as if something was stuck in the piston as it would be twice as fast.
i pulled the valve cover on the loud side and checked rockers push rods etc. everything looked to be ok.
but if i were to crack the fuel line to each cylinder at #7 the tick stopped.
i changed the injector with a known good one and no change tick still there.
Sooooo i figured something got in there and maybe went out the exhaust but damaged the piston skirt and was slapping when the injector fired.
so out it comes,
all other cylinders are fine #7 cylinder can be cleaned up with a light hone but the piston is junk.
everything above the rings is fine but the skirts are the only damaged area.
the crown is fine, no dents as if something got in there. and the flame pattern is about the same on all 8 pistons.
when i pulled the injection pump i noticed it was leaking a small amount of fuel out of what appears to be a vent hole at the bottom of it.
compression test before dis assembly 475 psi on all 8.
anyone ever see anything like this?
i have a new/rebuilt injection pump that i will be installing on this reassembly.
diesel fuel works as lube and feul in diesel not like gas motor and bad injetor that was cloged not give enought fuel and not enought lube it got hot and some thing happen i dont think u sucked in anything my 85 has a mesh girl under the air cleaner i think it was the lillte green men geting back at u with there alein tech lol iam a hoot
You something Joe....but a hoot, I don't think so! Your posts look like a kid puked up a bowl of alphabet soup.....spell checker and punctuation can be your friend.
The fuel lubricates the injection pump, not the piston skirts.
How did the injector look when you pulled it out? Did it come apart? Could it have washed that cylinder down?
I can't answer your question, Area 51 as I have just recently purchased my first IDI diesel and I am still trying to learn how they work although I am pretty mechanically inclined.
I would tend to think that the number 7 hole either leaned out and got hot, or washed down with fuel.
I am sure somebody will far more experience with these motors will be long to answer your question properly. From what I have read, when pushed too far, number 7 cylinder is the one to fail first on these motors.
I am gonna keep an eye on this thread in hopes to learn something useful....something other than the attack of little green men being the cause of the scoring.
