payload question
#211
Anyone happen to have a SCrew FX4 5.5 max tow and know thier payload? Got me curious.
I suspect this whole area will be Fords focus come the next full clean sheet redesign of the F150. Stiff chassis, with low enough curb weight that payload is not handicapped. Plus lighter the curb weigh the higher the mpg jumps. It all just snowballs. Thats why those engineers are getting the big bucks.
#212
A 3/4 or 1 ton truck is heavier and has heavier/stronger components than a 1/2 ton truck. These parts cost more to replace such as rotors, suspension parts, etc. Do you have any proof of the trucks getting the same fuel mileage?
#214
#215
As for the 250 using more gas and having higher operating costs--if you are pulling a 8-10k lb trailer or like that, it's unlikely that the gas mileage or operating costs will be *that* different between a 150 and a 250. You will definitely wear out/warp more brake rotors on the 150, and may also wear out or break more suspension parts due to them being more highly stressed.
Likewise, a Ranger will be much cheaper to operate than a 150 or a 250 as an empty truck, but hook up the 8k lb trailer to that and I bet your operating costs will go waaay up....if you survive.
George
#216
How many people with pickup trucks for work trucks are actually pulling around a 8-10k trailer all the time? How are you going to wear out the brakes and rotors on an F-150 faster if your trailer is properly set up with electric brakes? I hear people talk all the time about how they need super duper swiss cryogenic cheese rotors with super duper titanium pads because they tow trailers. I have working brakes on my trailers with a brake controller and therefore do not stress the truck brakes more than I would empty.
#218
one more head scratcher
ok, I suspect we are about to run out of steam on this thread. However, I have one more question.
If you look at the 2009 Towing guide, there is a pic of a red Lariat Crew, with trailer tow mirrors, running boards, moonroof, and a passenger in the front. It is towing a fifth wheel (perhaps Jayco) travel trailer.
I'm not a expert at travel trailers, but I believe that trailer must have a 1500+ pin weight. Based on the payload ratings I have seen, that must be overloaded.
Hmmm.
Hmmm.
#219
Hmmm.
Hmmm.
![Confused](images/smilies/confused0082.gif)
Personally, I think it is total BS that a truck like Bsimmer's is only rated for 900 lbs payload. Anyone who has ever hauled anything with one of these trucks knows that it is capable of carrying much more weight while still handling and braking very safely. But, apparently the other brands do the same thing. D@#! lawyers.
#220
Yes the extra rear leafs increase payload to cope with the extra tongue weight that may be used for the extra towing capacity. What i would like to know is what is the lariat able to carry when fully loaded and as if you built it to the same spec as my truck and fitted the 18's you only get the normal amount of leaf srings and no extra leaf's. I guess it would have an even lower payload than my 900lb as i have the extra leafs???? If that makes any sense.
#221
#222
I added something to my previous post you may want to check out.....anyhow, I can't answer your question exactly, but my truck is pretty close. The door sticker says 1257 lbs. Biggest differences between mine and yours (besides trim) are that I have 18" wheels and the 5.5' bed.
#223
I guess the laws the law for the GVWR and anything above that is not allowed. What i dont understand though is how a expy can have a higher GVWR?? It's a suv and aint really gonna be expected to haul anything and tow anything like a truck would. WHat i really find stupid more than anything is it's designed to fit 5 people in it but do they think everyone weights 180+ or less? I dont think i know one bloke 180 or under. So i can have 5 people in my truck but i have to make sure they are 2 ft tall and weight less than 180lbs each lol. Gonna have to start taking a scale out with me.
![Rolling Laughter](images/smilies2/happy0198.gif)
#224
No change in payload with the extra leaf. And its std w 20's. GVW and rear axle max ratings rule the day. And the f150 pulling the 5th wheel is Wayyyyyyyy over weight.
#225
And I did 24 once in my F150? Braggin' about mpg is like braggin about fishin. If I'm not there to witness I call BS. Who would get 3.55s in a F250 5.4L? You wouldn't be able to get out of your own way! If I got one it would be 3.73s m in, probably 4.10s.
