Sponsored by: Real Truck
Autometer gauge Question
Old Feb 20, 2009 | 07:00 AM
meanv10's Avatar
meanv10
Were would be a good spot to tie the gauge into so that when the key is turned the gauge turns on, I tried pulling mine out to look to see were I tied in but the wires and everything were to tight in there, any help would me great.
thanks
Old Feb 20, 2009 | 07:16 AM
shorebird's Avatar
shorebird
Which gauge are you writing about? Autometer makes several different styles. Is it an oil, vacuum, boost, amp meter, tach or any other of dozens?
Old Feb 20, 2009 | 07:24 AM
caprang's Avatar
caprang
you can tap in to a fuse. Just check them with a test light to find one that is key activated. You can also tap in to one of the wires coming from the ignition switch under the steering column.
Old Feb 20, 2009 | 07:48 AM
meanv10's Avatar
meanv10
The ones I’m putting in my buddy’s truck are Volts and Trans temp, there the c2 model, the gauge just needs the 12 volt source to turn them on when the key is turned forward. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Feb 21, 2009 | 12:48 AM
shorebird's Avatar
shorebird
Information from FTE member Relax
Posted in https://www.ford-trucks.com/forums/8...e-wire-it.html
IM him if this dosen't help.
2002 Ford Super Duty F Series Truck
| 12V|yellow & lt. grn/pur|+ |ignition harness |
| STARTER|green |+ |ignition harness |
| IGNITION|red/lt. green |+ |ignition harness |
| SECOND IGNITION|gray/yellow |+ |ignition harness |
| ACCESSORY|red/black |+ |ignition harness |
| SECOND ACCESSORY|blue/lt. green |+ |ignition harness |
| POWER LOCK|*1 | |*1 |
| POWER UNLOCK|*1 | |*1 |
| LOCK MOTOR|pink/black | |VSM *2 |
| UNLOCK MOTOR|red/orange | |VSM *2 |
| DISARM DEFEAT|pink/orange | |VSM *2 |
| PARKING LIGHTS +|brown | |headlight switch |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|black/lt. blue |+ |either kick panel |
| DOME SUPERVISION|use door trigger | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|*3 | |ignition coils |
| SPEED SENSE|gray/black | |instrument cluster or *4 |
| BRAKE WIRE|lt. green |+ | brake pedal switch |
| HORN TRIGGER|blue |- |steering column or VSM *2 |
| WIPERS|blue/orange |- |steering column |
| LF WINDOW UP/DN|wht/blk - tan/lt blu|A |driver window switch |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver kick panel |
| LR WINDOW UP/DN|gry/org - yel/lt blu|A |driver kick panel |
| RR WINDOW UP/DN|yel/blk - red/blk |A |driver kick panel |
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black/lt. green |- |radio |
| RADIO SWITCH|pink |+ |radio |
| RADIO ILLUMINATE|lt blue/red (dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio |
Old Feb 21, 2009 | 08:02 AM
meanv10's Avatar
meanv10
I ended up jumping it off of the delayed accessories fuse, and putting a 2 amp fuse in line with that. thanks for the help
Old Feb 21, 2009 | 08:14 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Don't know what year truck you're working on, but my 2004 has a "customer access" wire (don't recall the color but I can check if you'd like) behind the dash, just to the right of the pedals. I found it with a piece of heat shrink over the end, taped back to a wiring harness. This wire is hot when the key is in the run position, but not the accessory position.
This wire shows up as fuse #29 in my owner's manual.
Good Luck!
Josh88Ford
Sep 12, 2012 08:34 AM
sand_fiend
Mar 20, 2012 10:11 AM
k4uwc
Sep 28, 2009 07:58 PM
Z-MAN
Jan 15, 2008 07:46 PM
dlevey
Nov 24, 2004 10:35 PM
