Well I am now looking for one of these for my 94 F150. I can't find one anywhere. All the listings I found said discontinued and no longer available. I guess now would be a good time for one of the replacement lamp manufacturers to make one. The one I have is in fair usable condition, but looks bad. Most used ones I have found are far worse that the one I have. I know I revived an old thread, but its all the same information. I stumbled across my old post while searching for the light assembly.
I am considering possibly trying to use a light from a Super Duty. There is one in particular that looks really nice. I actually kinda like it better than the original one. Has anyone tried this?
Thanks for trying, but I have seen those. I would rather patch, smooth, and paint the opening in the cab than install that goofy looking junk on my truck. I wish they'd just make a decent reproduction one.
Yes, that is why they make different ones(one 94-97, one 99+)
I suspect I already know the answer, but has anyone tried putting one of these on a bricknose cab? I don't mind doing the wiring - I'd just add a toggle switch somewhere in the cab for the cargo light. The key item would just be getting something that had a matching contour.
I was just comparing the OEM light to a super duty light. The contour looks like it might work. The holes however are spaced farther apart, and the cargo light pods are probably too wide as well. I suppose new holes could be drilled in the cab, and the light pods trimmed down to fit the opening. I definitely do not like the thought of altering the cab, and will only attempt to make it work as a last resort.
