troubble shooting
Old Feb 19, 2009 | 04:21 PM
courios gorge's Avatar
courios gorge
troubble shooting
i have just put a offenhauser intake on my truck it is a 78 ford with a 400 and i put a 4 barrel carb on and it ran good more power but then i got a leak in my intake because i used the valley pan so i got the recomended gaskets i put them in and the leak has stopped but when i put the distibuter back in i back fired it through the carb and now my truck feels sluggish and underpowerd and it smells rich and i woundering if i blew out the power valve.
Old Feb 19, 2009 | 05:29 PM
75F350's Avatar
75F350
You have to first see and verify that you have the timing correct. If you backfired the engine through the carb, then the timing at some point was off. If that is the case, then you have to properly set that. Once you are confident that the timing is correct then you can address the carb issue.
Yes, if you run a Holley and you backfired through the carb, you can bet that the power valve has been destroyed. If it blew completely out, and it is torn, then fuel will be delivered and it will run rich during partial throttle and closed throttle operation.
Old Feb 19, 2009 | 05:35 PM
fmc400's Avatar
fmc400
MSEE
Your timing is off. You should have checked the base ignition timing with a timing light after you installed the distributor. Did you?
Old Feb 19, 2009 | 05:36 PM
akparker1's Avatar
akparker1
I'm with 75f350, power valve is my bet!
Old Feb 19, 2009 | 06:10 PM
andrewk's Avatar
andrewk
The power valve may have blown with the back fire, but you've got to make sure the timing is right on the distributor before you go messing with power valves.
Old Feb 20, 2009 | 07:34 AM
courios gorge
i do have the timming right after it back fired i realized i messed up so i re set the timing to the specs on the valve cover, so i think that my power valve is sol
Old Feb 20, 2009 | 08:31 AM
ubereal2's Avatar
ubereal2
If it's a Holley carb, yep you lost the power valve....
Old Feb 20, 2009 | 04:23 PM
courios gorge
you guys were right
the power vavle is junked so i orderd on from work, what is the best wat to set my float levle
lightning385
Apr 7, 2011 12:36 AM
arbuckles3
Dec 25, 2008 02:22 PM
stangfan78
Jun 25, 2008 07:59 PM
stangfan78
Jun 23, 2008 09:09 PM
tizzle
Jan 1, 2007 06:40 AM
