car wont start!
Old Feb 22, 2009 | 01:52 PM
  #46
QBANBOY407's Avatar
QBANBOY407
found the problem guys. the air compressor is bad!
Old Feb 22, 2009 | 05:08 PM
  #47
QBANBOY407's Avatar
QBANBOY407
thank you guys for all the help! i love this site!!!!
Old Feb 23, 2009 | 09:32 AM
  #48
texans's Avatar
texans
glad you found the problem. let us know if you need more help
Old Feb 23, 2009 | 09:35 AM
  #49
KR1's Avatar
KR1
So the AC compressor was stuck (bearing seized?, stuck on?)... and was dragging down the system...
well glad you figured it out... well if you have to replace that compressor, you would wish it was the battery or something else cheap..
Funny how so many people have different ideas on what could fix it...
Old Feb 23, 2009 | 07:26 PM
  #50
alloro's Avatar
alloro
A normal assumption would be that a seized pump motor would've blown a fuse. It's strange that it would suck down the battery and never blow the fuse.
Old Feb 24, 2009 | 08:23 AM
  #51
Eddie Hudson's Avatar
Eddie Hudson
Was it the Air Ride or Air Conditioning compressor which was bad? A fully charged battery should have started the truck right up. If the AC was seized the belt would squeal, if the AR was bad, the battery might run down over night. In any case the battery tested "good"
Old Mar 2, 2009 | 08:30 PM
  #52
jayram75's Avatar
jayram75
hey I had the same prob and alloro helped me without knowing it. My column shifter was loose and sometimes if the shifter wasnt in park all the way it would click and if in what looked like neutral it would not do anything. I tightened 2 torx screws on the shift linkage under the dash and it went away. My shifter tightened up and it starts everytime now. This site is great. If you try it and dont have a bigenough torx I used a metric allen key I cant remember the size but it fits perfectly. Hope this helps.
Old Mar 2, 2009 | 10:12 PM
  #53
alloro's Avatar
alloro
Perish the thought!
Old Mar 4, 2009 | 10:35 AM
  #54
wiredog's Avatar
wiredog
Key FOB or Keyless Entry
I have a 2003 Expy Eddie Bauer with keyless entry. Sometimes if I use my key to get in, it won't start either. If I have my key fob I just press the unlock and then it starts. Or I can get out and enter my keyless code and it will start too. It happens with whatever key I have at the time.
Old Mar 4, 2009 | 11:05 AM
  #55
texans's Avatar
texans
that would be the factroy security alram
Old Mar 4, 2009 | 07:54 PM
  #56
ford12508's Avatar
ford12508
I dont know how to word this correctly, but I will try.
If the problem was the chipped key, the car's engine would be cranking(Making the noise it makes when starting up), but would never fully turn over, it would just keep cranking. If you have a problem again, if this doesn't happen you can rule it out.
Old Mar 4, 2009 | 09:55 PM
  #57
alloro's Avatar
alloro
Actually if the chip in the key was no good then the starter is disabled and will not crank.
Old Mar 4, 2009 | 09:57 PM
  #58
ford12508's Avatar
ford12508
Well I had an non-programmed key and I tried to start my 99 Expy up and it just kept cranking. maybe its because the key was good but not programmed?
Old Mar 4, 2009 | 10:01 PM
  #59
alloro's Avatar
alloro
Odd...I wonder if something is wrong with your anti-theft system. The reason the starter is disabled is to prevent someone from crank the battery dead.
Old Mar 5, 2009 | 10:19 AM
  #60
KingRanchMan02's Avatar
KingRanchMan02
The starter is not disabled. If the chip in the key is wrong the engine will crank all day long but, it will never fire up and run.
