Are all ICP the same?
Old Feb 18, 2009 | 10:56 PM
hacksaw830's Avatar
hacksaw830
I just changed my ICP and spliced in the new pigtail. It says that its for a 04-07 6.0 but it looks different, my truck is an 04 but its an early build, will it matter? is this the upgrade I have read about? the ford number on the ICP is 4C3Z9F838A. Oyea whats the little tube of grease that comes in the kit? it has about a 4 page warning booklet with it, it looks like a little tube of dielectric grease. I hope I get my truck back together by friday, Im working on it a little at a time when I get home from work every evening.
Old Apr 13, 2009 | 11:59 AM
jobguy's Avatar
jobguy
ICP replacement from top or bottom?
Did you replace your ICP from the top or bottom? I have ordered my ICP sensor and pigtail, should be in mid week. If I do this job from the bottom how do you splice in the new connector? Thanks
Old Apr 13, 2009 | 02:58 PM
ljutic ss's Avatar
ljutic ss
He said he had an 04 it should be on the right valve cover not behind the turbo.
Old Apr 13, 2009 | 03:33 PM
jobguy's Avatar
jobguy
Thanks
I have an 03 and was trying to find out if there is enough wire slack to splice in the pigtail if I change the ICP sensor from the bottom.
Old Apr 13, 2009 | 04:57 PM
rangerbob406's Avatar
rangerbob406
what size socket did you use to renove the sensor does it have to be a special socket for sensors and why are you replacing the plug end is this necessary with all icp sensor replacements
cabloom300
Mar 22, 2019 10:00 AM
tjspates
Sep 21, 2015 03:14 PM
SOLOLUCKY
Jun 28, 2015 12:15 AM
dgulledge
Mar 10, 2015 07:33 PM
figurhead
Apr 20, 2014 01:26 PM
