Have you put any anti-freeze in there? If so, hopefully it was Ford Gold! If you didn't, are you running a tuner? Have you exceeded 30 on the boost gauge?
no i haven't i am getting ready to do a flush and fill on it and noticed it, i am not running a tuner im still new at this and trying to get the mods done but being on a budget isnt helping me or not having a place to work on the truck hurts to.
bismic
is that the only way to tell if it is the oil cooler or is there another way?
There is a TSB on a milky type substance for the coolant. TSB 08-23-1
Some 2003-2005 Excursion, 2003-2007 F-Super Duty and 2004-2008 E-Series vehicles equipped with a 6.0L engine may experience engine oil, transmission fluid or diesel fuel contaminating the cooling system. This flushing procedure is to be performed after the source of the cooling system contamination has been identified and repaired.
i don't know if its the oil cooler i have no signs of coolant in the oil also it has no smell to it, the cap smells like coolant. what does a new oil cooler cost and is it easy to replace.
No frustrations here - you have valid questions. I will say that some folks cling pretty strongly to the opinion that coolant will always get into the oil with blown oil coolers and head gaskets (in other words, they believe that if the coolant is not in the oil then they do not have an issue w/ these - that is just not the case).
Are you asking what the oil cooler "part" costs OR what it costs for a dealership to replace the oil cooler? Someone should come along and answer these (I can not recall, but I have seen it posted).
I know of no other way to confirm an oil cooler failure - except the oil emulsified in the coolant is a clear sign. The oil cooler failures usually occur when the coolant side of the heat exchanger plugs up with solids. This can be seen if you have gauges that show the Engine Oil temp and the Engine Coolant Temp. They should be within 15 degrees of each other.
I just got my 2004 out of the shop and they replaced a faulty oil cooler. Well guess what on a trip to San Diego pulling my fifth-wheel the oil temp would go to 255 while the water temp stayed below 225. A 30 degree difference. I guess my new oil cooler is bad too. So its back to the shop.
