Keep blowing thermostats
Old Feb 18, 2009 | 09:14 PM
92Renegade's Avatar
92Renegade
I am on my fifth thermostat this year. I have not been buying the cheap ones either. Each one has been $19.50 on the bill. Not sure of the brand but I know it is a 190. Any ideas on what might be causing this? It has a new radiator, waterpump, hoses, fresh full antifreeze.
Old Feb 18, 2009 | 10:24 PM
HrdDrv's Avatar
HrdDrv
Whaddya mean 'blowin 'em? Are they sticking closed? Open? Is it overheating? Not getting heat in the cab?
I would suggest putting thermostadt in pan of water, with temp guage, and see if it works within specs.. I would also try just putting gasket on the housing without 'stadt, and see what goes on.
Radiator fins/ac fins clogged/blocked?
Old Feb 19, 2009 | 06:20 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is there a spring in the lower rad hose?
If not and you've replaced everything else, that would be my bet.
It warms up and once it softens it gets sucked shut by the pump at revs.
Let off the throttle and pressure expands it to normal shape.
I doubt you've purchased 5 bad thermostats.
Old Feb 19, 2009 | 08:16 AM
1966Tbird's Avatar
1966Tbird
i second that
Old Feb 19, 2009 | 08:54 AM
quicklook2's Avatar
quicklook2
were they installed correctly?
Old Feb 19, 2009 | 09:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you mean is the thermostat 'right side up'?........
Neo01
Apr 27, 2015 10:54 PM
cworthington
1997 - 2003 F150
Feb 18, 2015 07:50 PM
rascal1
Aug 22, 2014 05:56 PM
yetiman38237
13
Apr 23, 2014 05:18 PM
Mark 42
13
Jun 6, 2010 10:08 AM
