Sponsored by: Real Truck
outside temperature/mpg overhead console
Old Feb 18, 2009 | 09:58 AM
switzj's Avatar
switzj
I have a 1999 F-250 V10. In the middle of top of cab I have a console that lets me know outside temperature, mpg, gallons left in fuel tank. This is very dim and I can hardly read this? Can I change the bulb to brighter one and if so how do I dismantle this?
Old Feb 18, 2009 | 10:28 AM
WhëëlMå1's Avatar
WhëëlMå1
Moved to appropriate forum
Old Feb 18, 2009 | 11:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The overhead gets dim when you turn on the head lights. I never heard of any way to make it brighter, but I have heard of people doing something to keep the light from becoming dim with the head lights on. I will look for a thread on this.
Old Feb 18, 2009 | 12:34 PM
Downriver Thunder's Avatar
Downriver Thunder
If it's getting dark enough where you can't see it then that means you probably had a diode or two break free of the circuit board. I had this happen in my Excursion. Had to buy a pencil soldering iron to fix the board. Just have to resolder them down.
Or you could just have the bright/dark switch turned down. ha ha
Old Feb 18, 2009 | 01:10 PM
miller_feed
Ok, I found the link for the overhead. click here. This will help you take it apart, not sure how to fix what you need.
Old Feb 18, 2009 | 03:27 PM
switzj's Avatar
switzj
Thank you very much! I will try this tonight.
Old Mar 17, 2009 | 02:16 AM
Jerry Edwards's Avatar
Jerry Edwards
Overhead Console
This is off base of the discussion,but i reset my console in my 02 f250 Lariot.The mileage and miles to go are never ending,the mileage now shows 35 miles to the gallen and when you get fuel it shows around 900 miles to go,but the temp is allways right.Did anyone ever have this problem?It never did this till i reset it.
Old Jun 5, 2010 | 12:01 PM
mmhancock's Avatar
mmhancock
Hey SwitzJ- did you ever find answer to your dim overhead console problem? I have the same issue and although it is not that important it does bother me and I would love to fix it. I can't read mine at all anymore.
Old Jun 5, 2010 | 02:53 PM
bpounds's Avatar
bpounds
I think this is the thread that you really want:
https://www.ford-trucks.com/forums/4...-gone-out.html
This is in the SD tech sticky at the top of the forum page.
Old Jun 5, 2010 | 10:29 PM
Jerry Edwards
overhead console
Thank You!
NELFLOW
Oct 21, 2015 07:03 PM
blackex
Oct 15, 2014 12:12 PM
ExpySport
13
Aug 30, 2014 06:58 PM
cutlass
Jun 13, 2012 11:18 PM
