Sponsored by: Real Truck
blew second plug same hole
Old Feb 17, 2009 | 08:55 PM
fomoco32's Avatar
fomoco32
Red face blew second plug same hole
I recently replaced my beloved 91 f 350. She had 350,000 on her 5.8l and was still going strong. Body and ele. system was getting tired. Replaced her with 2000 Ex. 6.8l. Though I got a good deal 4500. out the door with 121012 on the clock. All was well til tuneup time. After tuneup started blowing plugs. Never heard of that happening. Started doing my homework and found this to be a common problem. Seems like an easy fix though, tap the hole and use a save-a- tread insert. I have done this to 2 holes 15 min. job. Blew plug num. 3 now comes the bad news. Previous owner must have this happen as well and tried to repair using wrong size insert. The treads in the plug hole are all bugged up and the right insert goes round and round. Since the temp here hasn't been above 30 since Dec. I used j.b. weld as tread locker and 2 weeks latter, so far so good. My question is does anyone know if you can go double oversize on the insert. Also if I have to replace the head can you use the 3v head on a 2v block as I've heard the 3v heads are almost garrentied not to blow plugs.
Old Feb 18, 2009 | 08:12 AM
vettdvr's Avatar
vettdvr
Ok you have a problem. I have seen (don't know if this is possible on yours) a pipe nipple cut to fit and taper threaded into a cylinder head. Then the pipe internals were cut to fit the spark plug. Short of something drastic like this I think a machine shop is your only choice or replacement head. Best of luck on this very difficult problem
Old Feb 18, 2009 | 05:44 PM
shorebird's Avatar
shorebird
Stop and contact Blownoutsparkplug.com
Old Feb 18, 2009 | 05:58 PM
vettdvr's Avatar
vettdvr
This is interesting. It is very similar to the taper pipe nipple end that I have seen used on a previous engine. The taper has better gripping force than the straight thread replacement. When I covered the pipe nipple this was to form the taper thread section. Then it would have to be internally threaded to match the plug. What was on the site was almost identical to the pipe nipple repair however more professionally done as we didn't have all the machine tools.
Old Feb 18, 2009 | 08:45 PM
high ho silver's Avatar
high ho silver
Whewww. Saw the thread title and thought I was gonna have to report an x-rated posting.
Old Feb 18, 2009 | 10:56 PM
99f350sd's Avatar
99f350sd
timesert has the repair for you.
http://www.timesert.com/html/bigsert.html
Old Feb 19, 2009 | 07:08 AM
rwilimo's Avatar
rwilimo
X2 on the Timesert, I use them in the shop. They are not cheap, but do work very well.
Old Feb 19, 2009 | 10:24 AM
mhoefer's Avatar
mhoefer
The 3v head wont be an easy bolt on. What I think you want is the later 2v head with the increased thread for the plug. There was an update on the later models, pre 2005 when the 3v came in. Or you could replace the whole engine and tranny with a 3v and torqueshift :-)
Old Feb 19, 2009 | 10:47 AM
99f350sd's Avatar
99f350sd
No need to replace head....usually ..Tmesert will repair permanently...
tmehrkam
Modular V10 (6.8l)
71
Mar 19, 2025 10:22 PM
coloradoclimber
Modular V10 (6.8l)
Jan 13, 2014 07:35 AM
videopro192
15
Feb 1, 2010 03:02 PM
mwsF250
Modular V10 (6.8l)
24
Dec 2, 2008 09:46 AM
michaelmueller
Modular V10 (6.8l)
16
Feb 22, 2007 02:44 PM
