Front Diff. Leak
Old Feb 17, 2009 | 01:38 PM
dougwood62's Avatar
dougwood62
Front Diff. Leak
Has anyone ever changed the seal on the front diff. where the drive shaft comes in? Is it easy to do yourself or do you recommend having someone else do it?
Old Feb 17, 2009 | 01:55 PM
BENG0924's Avatar
BENG0924
I think your speaking of the pinion seal. Not a bad job I do recomend gettin all your tools together before you start the job or you will make many trips to the parts store. Ask me how I know. My leak was on the rear tho.
Old Feb 17, 2009 | 02:06 PM
dougwood62's Avatar
dougwood62
Ya it is the pinion seal. I couldn't for the life of me think of what it is called. Could anyone tell me the process and everything I will need so I won't have to go to the parts house a million time? pictures would be nice too.
Old Feb 17, 2009 | 02:21 PM
BENG0924's Avatar
BENG0924
let me see what I can dig up.
Old Feb 17, 2009 | 03:15 PM
BENG0924's Avatar
BENG0924
Im not sure about the front. I think it should be pretty easy the rear has a crush sleeve and you have to set the depth correctly ot it is problematic. The dana 60 shouldnt have a crush washer so its pretty simple. TIPS
- Mark driveshaft to yoke orientation then remove
- have a 2 or 3 jaw puller on hand for yoke removal
Other than that it should be pretty easy.
Old Feb 17, 2009 | 04:02 PM
rbaker6336's Avatar
rbaker6336
you can get a Dana service manual here,as well as drive shaft parts and infi
The Expert - Librarian - Information for driveshafts, u-joints, axles, heavy axles, light axles, Driveline
Old Feb 17, 2009 | 08:30 PM
dougwood62's Avatar
dougwood62
That Dana manual helps alot. Would you recommend changing anything else while I'm at it. I noticed that when I take the yolk off I will be able to get to a bearing. but that is about it. I guess I could just check it and grease it.
Old Feb 17, 2009 | 08:59 PM
rbaker6336's Avatar
rbaker6336
I would check the bearings to see if they are loose.Most of my front pinion seal problems have been caused by play in the pinion bearings
bobalonius
Apr 6, 2012 05:19 AM
shapel
Feb 2, 2011 05:40 PM
Dirtrider0213
Nov 18, 2009 12:26 PM
navifused
Oct 27, 2009 06:36 AM
wmiller
Jul 20, 2008 01:53 PM
