Electrical Problem - Starting - Hot ground cable
Old Feb 17, 2009 | 12:31 PM
Fluid Power's Avatar
Fluid Power
I've been having some issues when cold starting my 2004 6.0.
First of all, it has to crank for longer than average to get it started. If I cycle the glow plugs more than once (ie.failed start) my batteries become sooo weak they'll barely start the truck. Most importantly, I can smell burning from under the hood that would appear to be comming from a ground strap on the back of the passenger side of the engine compartment.
The batteries are brand new, I replaced them because I thought that they were my problem...not!
Battery cables are all in good shape too.
Any thoughts??
Old Feb 17, 2009 | 12:53 PM
Benchwrench's Avatar
Benchwrench
you may have more than one issue going on here.
You might have a bad battery (eventhough it's new)
One or more battery cable(s) are internally faulty, the terminals are internally corroded,
there may be a weak connection at the frame.
The starter might be faulty.
you have many possibilities, you might have to do some more poking around testing the cables, batteries and starter.
Old Feb 17, 2009 | 01:12 PM
cartmanea's Avatar
cartmanea
I'd figure out that ground strap first, if its getting hot it is either loose or gone bad either with corrosion or physical damage.
Old Feb 17, 2009 | 04:59 PM
Fluid Power
I think I just realized something else.....
This only seems to happen when I'm using my command-start. I was thinking of maybe adjusting my timer settings on my remote starter. But I don't know where it is or how to change it. I bought the truck second-hand and I have no info on the system.
Is there a spot where these things commonly get installed?
