AE scanner
Old Feb 26, 2009 | 04:32 PM
rjmjr78's Avatar
rjmjr78
thanks, I may need it
Hopefully I can get it fixed with enough time to go home for a few days before we go back to work
Old Feb 26, 2009 | 05:05 PM
megawatt00's Avatar
megawatt00
When you pulled the valve covers off did you make sure that the connectors were plugged in correctly?
Old Feb 26, 2009 | 05:15 PM
rjmjr78's Avatar
rjmjr78
Yes, but I only pulled the drivers side.
Old Feb 26, 2009 | 06:05 PM
megawatt00's Avatar
megawatt00
If you have a multi meter you can ohm out the injectors. Rough running may be caused by a loose UVCH.
Old Feb 26, 2009 | 06:30 PM
rjmjr78's Avatar
rjmjr78
Yes, I also checked that, everything seemed to be good
Old Feb 26, 2009 | 06:55 PM
F350-6's Avatar
F350-6
Pull the valve cover back off and unplug one of the injectors that's not spitting any oil. If there's no change in how the truck runs, then that injector is not firing.
Old Feb 26, 2009 | 07:00 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thanks Jim and Chris, I was not getting anywhere with his problem. I hope he can get home.
Old Feb 26, 2009 | 07:05 PM
rjmjr78's Avatar
rjmjr78
When I unhook anyone of the injectors, it runs rougher and makes the ses light come on
Old Feb 26, 2009 | 07:09 PM
megawatt00's Avatar
megawatt00
Including the ones that are not spitting oil?
Old Feb 26, 2009 | 07:15 PM
rjmjr78's Avatar
rjmjr78
Yes, I think that my icp may be bad also, when I unplugged it, there was oil in there, and the truck run different, not so much better, just different
Old Feb 26, 2009 | 07:16 PM
miller_feed
I'm still thinking its a trans problem. But I don't know.
Old Feb 26, 2009 | 07:21 PM
rjmjr78's Avatar
rjmjr78
Would the AE scanner tell me that? I would like to get one for myself, but need a new computer first(my computer is older than my truck).
Old Feb 26, 2009 | 07:30 PM
  #28
F350-6's Avatar
F350-6
What happens if you remove the oil fill cap when the truck is at idle? Do you see some smoke? Is it a steady stream of smoke, or is it a puff, puff, puff that you can feel by placing your hand over the tube?
Old Feb 26, 2009 | 07:35 PM
  #29
rjmjr78's Avatar
rjmjr78
I don't know, haven't checked that.
Old Feb 26, 2009 | 07:38 PM
  #30
rjmjr78's Avatar
rjmjr78
Does it matter if the engine is warm or cold? I can check now, but it's been setting for four or five days.
