Hi everyone, considering replacing my fiance's 92 Honda Civic with an Explorer. She really likes the '95-'01 body style, as do I. I was just wondering if there are any particular problem areas to look for. We would like to find an Eddie Bauer or Limited with the 4.0 SOHC and 4x4. What kind of mileage can I expect out of it? Thanks for any info.
i bought a 96 wiht about 140k miles for the kids to play with. In the last two years i have replaced the alternator, both front wheel bearings, fan belt, and idler pulley/bracket, brakes and brake lines . The guy before me had nenw lower ball joints installed in the front. I dont think the above is bad, i had planned on that. If your not expecting some maint on a truck with over 100k miles, you will be dissapointed. The motor and transmission run great. It gets 19.5 to 20 MPG on the highway. It is a 6 cyl, 4 speed auto.
Wifes 97 explorer limited has been relatively trouble free (needed a EATC blower motor resister) and at 125,000 miles uses no oil. gets about 16/17 city 24hi way with 4.0 v6.
Don't get the 5.0 V8, it's a real gas hog (16.6 mpg hiway is best mine ever does). Too scared to check city mpg. 121K miles on it and the only real expense has been one front wheel bearing (pricey) and 2 brake jobs.
My 5.0 AWD with 184,000+ miles gets 21.7 mpg highway, and 18.5 city. It still runs great and has been a great vehicle.
From what I've read in the forums, it doesn't sound like the mgp between the 4.0 and 5.0 is that significant. I'm sure others will jump in with opinions. Keep in mind that many of the 5.0s have AWD instead of 4wd. AWD can cost you some extra mpg as well.
I was talking to a guy at work that has an '03 with the 4.0. It has 125,000 miles on it and the timing chain (belt?) just broke out of the blue. It put a hole in the valve cover about the size of a golf ball, and who knows how much damage internally. So I'm starting to reconsider the 4.0 now. Was the V-8 only available with AWD?
I'm guessing you read my post just above yours? Between the timing issue and the weaker transmission, both very expensive repairs, I can't see how 1 or 2 mpg could ever offset the repair cost.
The 5.0 was either AWD or 2 wheel drive, and was never offered with a selectable transfer case.
The AWD Explorer is the best vehicle I've ever driven in the snow, but I don't think that is a concern for you since you live in Florida. I would love to find a 2wd 5.0 Explorer, but there aren't many of them in my area.
I'm not sure the years it was available, but the 4.0 OHV motor is a lot more reliable than the SOHC motor, although it has nothing for power compared to the 4.0 SOHC or the 5.0
