New guy with a 460
Old Feb 15, 2009 | 12:14 PM
mrwilliam of texas's Avatar
mrwilliam of texas
New guy with a 460
Hi guys,
I just bought a big 97' F350CC with the bigblock 460, it has tons of miles on it..(250k+) But .. i jumped on it do to how clean it is, truck runs great shifts good and is over all in great shape..
My question is, should i let things run there course or should i take the truck in for somesort of overhaul or rebuild before something happens?
At this point i dont have any reason to suspect issues, but miles are miles..
Thanks guys... Have a great day!
Old Feb 15, 2009 | 12:35 PM
Bear 45/70's Avatar
Bear 45/70
If it ain't broke, why fix it?
Old Feb 15, 2009 | 12:40 PM
mrwilliam of texas
haha..cant go wrong with old sayings....
Old Feb 15, 2009 | 12:56 PM
monsterbaby's Avatar
monsterbaby
Welcome to FTE
Only thing I would do is your basic maintenance, change fluid, do a tune up grease everything and run it until you find a problem that needs fixed.
Old Feb 15, 2009 | 12:58 PM
Bear 45/70's Avatar
Bear 45/70
In this case it is true. My 1984 carbed 460 has 264K on it and it isn't smoking or using oil at a faster rate than a quart every oil change (5K to 7K miles) and the mileage remains as always.
Old Feb 15, 2009 | 03:46 PM
mrwilliam of texas
Thanks gents... The only noticable area of oil gathering on this truck is in the rear main seal area.. But there is not a "leak" in the sense that there is dripping, but gathering nun the less...
Thanks for the input guys, i welcome more input if anyone wants to share...
Old Feb 15, 2009 | 04:03 PM
darrin1999's Avatar
darrin1999
at that kind of miles you may want to double-check the timing chain for slop, or just replace the timing set. thats about all id recommend besides basic tune-ups and lube changes. if that chain breaks youre replacing valves and possibly pistons
Old Feb 15, 2009 | 04:29 PM
mrwilliam of texas
Thanks for that idea..! ive had to do that to my family toyota(gulp) but it was a job..
I will take the truck in to have that done.. i have a huge trip planned ahead and would like to take the truck.. so.. better safe then sorry..
Old Feb 18, 2009 | 05:17 PM
mrwilliam of texas
what does it mean when the od light in the shifter *** is flashing?
Old Feb 18, 2009 | 05:48 PM
monsterbaby
that is just like the check engine light only for your transmission, it has a code and you need to get a code reader than can check transmission codes and find out what it is.
Old Feb 18, 2009 | 06:11 PM
mrwilliam of texas
Great!! just bought it and this is happening already!!
Old Feb 18, 2009 | 07:00 PM
monsterbaby
Don't get all worried, might not be anything serious, get the codes checked, and then you can post up in the forum for your truck to see if someone can help you with that issue.
https://www.ford-trucks.com/forums/forum28/
Or maybe
https://www.ford-trucks.com/forums/forum30/
Old Feb 18, 2009 | 07:43 PM
mrwilliam of texas
Thanks man!!
GreenMachinee
Oct 30, 2014 10:32 AM
Ghostka78
16
Jul 13, 2014 03:37 PM
jfaber
13
Nov 20, 2009 09:12 PM
quantrellc
Jan 8, 2007 06:36 PM
AZ 56 & 03
Modular V10 (6.8l)
Nov 22, 2006 01:08 AM
