Hello everyone
Old Feb 16, 2009 | 09:21 AM
Ponyboychris's Avatar
Ponyboychris
Is there any metal tags on the rear end cover?
Old Feb 16, 2009 | 09:33 AM
Izzy351's Avatar
Izzy351
The OM says it's a 29 gallon tank, but I have personally put over 34 gallons in it after being bone empty from doing the in-tank mods. If you do the in-tank mods, you'll be able to fill it to the neck easily every time and get a good mileage calculation. By the time I get fuel, I put 30-31 gallons in it filling it that way. I just calculated mine at 15 even, and I don't drive mine like grandpa. LOL....
Look on the inside of the driver's door jamb -- should be a sticker there that says "Axle" on it. Right under that are some letters/numbers. It probably says "C1", which is a LS 3.73 diff. If it's not, look it up here:
What is my Ford rear end ratio, do I have positraction - Drivetrain.com
Old Feb 16, 2009 | 05:41 PM
caseydudem's Avatar
caseydudem
Thanks for the help. I will check as soon as my truck gets back.
29 gal doesn't sound good. I have only a 150 miles and that consumed the first half of the tank.
29/2=14.5
150/14.5=10.3
I was hoping for atleast 15.
Old Feb 16, 2009 | 05:46 PM
61 uni's Avatar
61 uni
casey, were you the one stationed in germany?
Old Feb 16, 2009 | 06:01 PM
caseydudem's Avatar
caseydudem
Yep thats me
Old Feb 16, 2009 | 06:06 PM
61 uni's Avatar
61 uni
You sell your truck over there? I to have moved onto a super duty and couldn't be happier.
Old Feb 16, 2009 | 06:13 PM
F350-6's Avatar
F350-6
29/2=14.5
150/14.5=10.3
You can ignore that kind of math. Do it the old fashioned way calculating miles with how many gallons it takes to refill. The needle tends to hang up in certain spots and move real fast in others. A half a tank on the gauge doesn't mean you actually have a tank that's half full.
Old Feb 16, 2009 | 06:23 PM
caseydudem's Avatar
caseydudem
Yep I sold it just four months before we moved.
Old Feb 16, 2009 | 07:08 PM
caseydudem's Avatar
caseydudem
I added my truck to my albums for everyone. Looks pretty good for an 02?
