Sponsored by: Real Truck
I'm confused
Old Feb 15, 2009 | 09:41 AM
rtc722's Avatar
rtc722
I'm confused
Just replaced waterpump on my 99 F350. The thermostat is still leaking. Replaced thermo & seal. About 3 months ago replaced upper housing. Why won't it seal,should I replace the upper housing again & get new bolts?
Old Feb 15, 2009 | 09:46 AM
meanv10's Avatar
meanv10
dono, but if all else fails I would try some High temp RTV sealer, that would be alot cheaper than replacing the manifold. That is strange.
Old Feb 15, 2009 | 09:47 AM
Furian's Avatar
Furian
You Keep What You Kill
Was the thermostat leaking BEFORE you replaced the water pump? Also, what engine do you have in the truck?
Old Feb 15, 2009 | 09:48 AM
Rongold's Avatar
Rongold
Unhappy Leaking
Don't know. You never filled out your profile, and we don't know what engine is in your truck. Do everyone a favor, and FILL OUT YOUR PROFILE !!!
Old Feb 15, 2009 | 10:15 AM
rtc722's Avatar
rtc722
Opps. It has the 7.3 psd. Don't think thermo was leaking before new pump.
Old Feb 15, 2009 | 11:29 AM
redford's Avatar
redford
FTE Leadership Emeritus
The new upper housing you put on isn't any good. Sounds like it isn't sealing.
I would try a new one.
Old Feb 15, 2009 | 11:51 AM
rtc722's Avatar
rtc722
Thats kinda what I figured. Thanks for your input guys. Still working on that profile,I'll get it soon.
Old Feb 15, 2009 | 12:21 PM
Furian's Avatar
Furian
Welcome to the forum rtc722! We look forward to your future threads and posts!
Old Feb 15, 2009 | 09:57 PM
Steve_250's Avatar
Steve_250
Here, get the billet housing and scroll down for the 203* thermostat.
That stamped crap doesn't last more than one time on.
Old Feb 15, 2009 | 11:48 PM
bayou barataria's Avatar
bayou barataria
Try indian head gasket comound, that stuff will seal anything.
Old Feb 16, 2009 | 12:07 AM
TPM's Avatar
TPM
Do not use high temp sealant if you have an oil cooler on the side of the engine. Trust me - I had to pull threads of it out of the oil cooler. From what i know of these engines, none of the surfaces should require a RTV to seal.
