Does anyone know what the touque spec is for the gear bolt on the HPOP? I am putting in my TE SD pump tomorrow and I was just wondering. I would hate for that thing to back its way out of there!!!!
when you are cranking down on it you will eventually turn the engine over a little bit. that's how far we take it. once it turns the engine over a little give it one more good pop and it will be good. haha
Hey guys thanks for all the help. I got it in today. It took me about 4 hours by the time I replaced the serpentine belt, the pump, and checked for leaks. The install went very smooth with no major hicups.
I noticed a little more pull on the top end with the new pump and less drop in rpm's between shifts. What did those of you with a 17* pump notice after your install besides hard starts for a little while?
