Sponsored by: Real Truck
Turbo hoses
Old Feb 14, 2009 | 06:18 PM
Greenlawnracing's Avatar
Greenlawnracing
Turbo hoses
While getting my CPS sensor recall done at the stealership today, the service advisor told me that the rubber hoses going in and out of my turbo were a little lose. (Forget the technical name for them, one of them goes to the exhaust downpipe)
He offered to take them off, clean them, and reseal them for the low low price of $100.
I asked him what they use to seal them with, and he wasn't sure.
Anybody have any idea what one should use to seal them with? If I truly am having a little bit of oil blow as he stated...I'll certainly take ten minutes to seal them back up.
Old Feb 14, 2009 | 06:30 PM
X GM GUY's Avatar
X GM GUY
I sprayed the hose with some brake cleaner, to remove the oil, then used a hi temp silicone to seal the hose. Dealer said it wouldn't work, but have had no leaks since.
Old Feb 14, 2009 | 10:09 PM
F350-6's Avatar
F350-6
Those are your boots on the intercooler plumbing. Take them off and clean them up if you want, or if they haven't been taken off, just tighten them back down. Remember they attach to soft pieces so don't over tighten them. The spec is 70 in-lbs.
I'm assuming with the CPS recall you've got a 7.3 motor. Be sure to check out the 7.3 diesel section further down the main forum listing. If you want to take them off and clean them, you can usually get them pretty clean with just a rag and maybe something like simple green that won't hurt the boots. A shot of hair spray on the inside of the boots will provide a tacky surface that will help to keep them from popping off after re-install. If you want to eliminate that oily residue, check out the CCV mod down in the 7.3 section.
Old Feb 14, 2009 | 10:18 PM
Stewart_H's Avatar
Stewart_H
[pointing up] What Chris said.
Stewart
Old Feb 14, 2009 | 11:08 PM
Greenlawnracing
I didn't realize there was a diesel section on this forum - can one of the mods move this thread?
Yep, its a 7.3.
The boots have been off before, because I had to take off both valve covers a couple of years ago.
Is there no sealant that I'm supposed to use?
Got a link to the CCV mod?
Old Feb 15, 2009 | 12:39 AM
Stewart_H's Avatar
Stewart_H
Welcome to guzzle's Ford PSD Web Pages
You'll find a ton of great info there.
Click the link on the left side that takes you to the mod page. The CCV mod is the first one listed.
Stewart
Old Feb 15, 2009 | 07:03 AM
big poppa's Avatar
big poppa
Save that 100 bucks for something for your truck and come on down to the 7.3, lots of info as stated above.
The Masked Rider
13
May 13, 2014 05:34 PM
big 390
2004 - 2008 F150
Mar 4, 2012 11:10 PM
paddler
Apr 4, 2011 08:24 AM
Sycostang67
Mar 29, 2010 08:34 PM
Avanti
Feb 13, 2003 12:50 PM
