I almost gave up.
Old Mar 29, 2010 | 02:45 AM
Sycostang67's Avatar
Sycostang67
Red face I almost gave up.
When it takes 12.5 hours to change injectors, you might think about it too. Apparently the copper seals had failed on two of my injectors, causing what little space there was to become hard packed with fuel and soot. I knew I had a compression leak on one injector, but not two. I had to use a slide hammer to remove them, then I had to lay on the motor with picks, a flashlight, and a vacumn scraping the crud out of the bores. One of them had to be the far injector next to the turbo. Thankfully my best friend was there to help me and keep my temper in check, I couldn't have done it without him. The truck is alive again and will hopefully get the timing checked this week. I dont plan on dropping the hammer until I know everything is kosher with the timing.
Old Mar 29, 2010 | 03:34 AM
LCAM-01XA's Avatar
LCAM-01XA
So I was right warning you about them injectors, unfortunately... At least yours unscrewed, one of mine is so stuck I had to use a 3ft cheater pipe on the breaker bar to get it to even turn!!! Needless to say that injector is still on the engine
Old Mar 29, 2010 | 06:57 AM
mechelement's Avatar
mechelement
Did you start with a cold motor or a warm one? Does it matter? At least you got all of them out.
Old Mar 29, 2010 | 08:57 AM
starmilt's Avatar
starmilt
There is a special tool to clean/scrape the injector bores for our motors. I don't know anybody that has used one, but I know it is available.
Old Mar 29, 2010 | 09:34 AM
RCrawler's Avatar
RCrawler
I used an injector bore brush when I did mine. But I didn't have an excessive amount of buildup to deal with.
Jason
Old Mar 29, 2010 | 12:28 PM
Sycostang67
Thats what we were doing, breaker bar with a cheater pipe. I thought about just putting it back, but after it unthreaded and wouldn't come out the top, it wouldn't go back in either.
Motor was cold, truck had been sitting the last 2 days.
I had to get a new socket set since I needed a deep 1" socket for the injectors. I had wrenches but they just kept slipping off. I also had to buy a shotgun cleaning kit to clean the bores out. It had wire brushes and fuzzy ones to wipe them clean. I guess I could use it on my paintball gun as well.
Old Mar 29, 2010 | 03:04 PM
m-hickey95's Avatar
m-hickey95
I just replaced the injectors in mine as well but I didn't do any cleaning in the bores. I pretty much just removed and replaced. How critical is it to clean out the bores? Will the new injectors not seat propery?
I would not be looking forward to pulling them out again that's for sure.
Old Mar 29, 2010 | 04:53 PM
Sycostang67
It's possible you could end up with a compression leak if the copper washers dont seal properly. Then you may get to share my experience of crud caked injectors that refuse to leave.
Old Mar 29, 2010 | 06:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
oh man what a day you had.
good to hear you got 'em all cleaned out and changed.
i'll be smothering them mothers with anti-seize when the time comes.
Old Mar 29, 2010 | 08:34 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I ain't looking forward to doing mine. Been on there for a long time. Awfull rusty to!
If one wasn't leaking and causing a knock on start up I would let 'em be.
But been knocking abit to long now, getting worried!
Kwikkordead
63
Feb 11, 2017 03:42 PM
catman52987
Jan 29, 2012 10:37 PM
Sycostang67
13
Jan 17, 2012 09:08 AM
Hotwheelbill
Jan 21, 2006 02:26 PM
labrat86
May 18, 2004 11:15 AM
