Aerostar Ford Aerostar
Power Steering Pump Question:
Old Feb 17, 2009 | 07:30 PM
AutoAppearancesInc's Avatar
AutoAppearancesInc
The pop can trick meaning for the drainage of rain water?
What is the best way to flush it out? Oops!! is there a sticky on that?
Old Feb 17, 2009 | 09:39 PM
marty600's Avatar
marty600
Cut a soda can in half, and place the bottom section over your PS cap,
looks ghetto, but vent in cap still works, and no water gets in
( I lost a pump from alot of rain, in wintertime..it froze in the system, there was so much water in there. However, I was missing the 'downspout' thingy,
new van and was too busy to notice.
I had to flush, it's easy with 2 people. Just disconnect the return line from the PS cooler (it's the one that feed into the bottom of resevoir),
plug the line from the res. good. the open line goes into a big container (gal)
THAT is where the fliud will be force fed out of.
The system will pump out so fast, you will be pouring PS in as fast as you can (have helper start car and turn steeringwheel end-to-end)
Knowing the rate of discharge, I made a fitting for when i flushed the diesel
PS out, and gave it a hole of .125. That made no difference!
If you have a lathe and want to make a plug-w-hole to slow down the rate
of fluid loss, try .0625 or 1/16.
Old Feb 17, 2009 | 09:52 PM
AutoAppearancesInc
Getto!!! That's my middle name...
Hey if it works, who cares what it looks like!!!...
Thanks so much for the flush info..
Old Feb 17, 2009 | 10:18 PM
marty600's Avatar
marty600
In the bitter end of our 2nd Aeros' life, it was covered in rust due to il. heavy salt useage...It became known as "THE GHETTO CRUISER"
I loved driving it to work then, nobody challenged me.
Old Feb 18, 2009 | 04:28 PM
AutoAppearancesInc
Well I finished up the install today...
It went well, the pump works great..
There was some foamy fluid in there..
I just sucked out the fluid from the pump twice.. that seemed to clear it up.
I will check in the morning,, I will most likely flush the system in the morning..
Next job on my list is replacing the rear ' U ' joint....
Thanks for all your help..
Old Feb 19, 2009 | 04:53 AM
Pablo-UA's Avatar
Pablo-UA
Replace rear UJ. No press, so we gonna do all with hummer. Ya! BTW, there are sprays, like WD-40 but for aluminium. Use them. less problen nocking out old UJ.
Old Feb 19, 2009 | 12:30 PM
AutoAppearancesInc
Marty600:
Let me start with sorry for my confused state here!!
Well i went out this morning to take the kids to school started the van and noticed some noise from teh steering, I checked the fluid,, and DARN it I guess I needed to do a real flush yesterday... I turned it off and used my other work van today...
So let me see if i have this correct:
1. I need 2 people
2. disconnect the return line from the PS cooler (it's the one that feed into the bottom of resevoir),
3. plug the line from the res.
What are some options for pluging this line??????
4. the open line goes into a big container (gal)
The system will pump out so fast, you will be pouring PS in as fast as you can (have helper start car and turn steering wheel end-to-end)
Don't I have to have another line from the system in a another container for drainage of the old fluid??
Sorry if this sounds like a stupid question!!!
RojoStar
Aerostar
27
Jun 30, 2022 02:21 PM
AutoAppearancesInc
Aerostar
Apr 3, 2018 06:25 PM
razor_jim
Aerostar
35
Mar 9, 2017 03:17 PM
AutoAppearancesInc
Aerostar
13
Jan 29, 2016 04:02 PM
AutoAppearancesInc
Aerostar
May 7, 2009 09:35 PM
