ebvp? wtf
Old Feb 12, 2009 | 10:44 PM
mater78's Avatar
mater78
ebvp? wtf
i went out to eat tonight and was there for about 4 hours. temps are in the 20s and the truck was up to temp when parked. Went to leave let the truck run for a min and left. truck had ZERO power barley 20mph. cont down the road and up a pretty good grade (hill) 10mph at 1500rpm almost didnt make the hill. made it up the hill pulled into a parking lot then everything was normal. Was this due to cold temp and evbp. please help
Old Feb 13, 2009 | 05:59 AM
wreckit72's Avatar
wreckit72
You can just unplug the connector to the EBPV and you won't have that problem anymore.
Old Feb 13, 2009 | 06:09 AM
mater78's Avatar
mater78
how bad will it effect warm up time/ cold weather driving?
Old Feb 13, 2009 | 06:18 AM
tjbeggs's Avatar
tjbeggs
Not in my experience. No change in warm up time or operating temp.
Old Feb 13, 2009 | 09:36 AM
cowmilker08's Avatar
cowmilker08
x2 no change, if anything warm up time is quicker but nothing to write home about.
Old Feb 13, 2009 | 10:12 AM
MADVAN's Avatar
MADVAN
How is warmup quicker?
Use of the valve has a small effect on warmup.
It does a better job at controlling startup/cold smoke.
Bill
Old Feb 13, 2009 | 10:19 AM
cowmilker08
just from from experience, it doesn't make much sence to me either. but when i unplugged mine it seemed to warm up slightly faster, but only by about two to three minutes at idle.
Old Feb 13, 2009 | 10:33 AM
MADVAN's Avatar
MADVAN
Impossible to be quicker warmup without.
Bill
Old Feb 13, 2009 | 10:42 AM
cowmilker08
theoretically yes
but thats what i've observed
Old Feb 13, 2009 | 11:34 PM
mater78's Avatar
mater78
Did it again tonight. Pleasd tell me were this connector is so i can unplug the *******. Do i need to do it on a warm or cold engine to ensure that that the valve is open.
Old Feb 14, 2009 | 12:05 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
i dont think it matters when you unhook it doesnt engage
Old Feb 15, 2009 | 01:01 PM
cowmilker08
i unplugged mine when it was cold.
Old Feb 15, 2009 | 02:46 PM
884x4broncoII's Avatar
884x4broncoII
i unpluged mine and dont miss it one bit
Old Feb 15, 2009 | 07:35 PM
Todd525's Avatar
Todd525
If your looking for the connector, it should be right under the turbo on the drivers side of the truck in the valley.
It doesnt matter if you unplug it while the motor is warm or cold. Absolutley none.
I have no idea what COWMILKER is talking about. Apparently the laws of physics dont apply where he lives. Bill and others are correct, it helps, but is more or less worthless. Its like ading 30 pounds to the rear of a 2wd truck in the snow, it helps, but if you can tell, your better than the other 300 people on here that have built their trucks from the ground up...LOL
Old Feb 15, 2009 | 08:33 PM
Vinford's Avatar
Vinford
I unplugged mine and it opened and shut whenever it wanted.
My truck didnt run proper for 2 months or so until I figured this out.
I have no wired it open and everything seems OK other than its pretty cold here and the truck seems to smoke alot until it warms up.
But once ot warms up.......
