Power steering
Old Feb 10, 2014 | 09:55 AM
jmikeyj4's Avatar
jmikeyj4
Power steering
Hey guys so power steering went the other day in my 94 f-150 but i cant figure out why? it is not leaking and still holding fluid. The Fluid is still pumping through the lines cant figure it out?
Old Feb 10, 2014 | 01:37 PM
dixie460's Avatar
dixie460
Yeah I had that happen too on my old F-250. Unfortunately I never fixed it before I got rid of the truck, so I don't know what caused it. Just dumped all hydraulic pressure one day after I hit a rut, and never worked again.
Best thing I can suggest would be to tee into the discharge side of the hydraulic pump and see what the pressure is. You'll probably be fine with a 3000 PSI gauge from a hydraulic supply place... I don't think the pressure is much over 1500 PSI or something at full load (wheels turned to the stops).
Subscribing, I'd like to know what happens.
Old Feb 11, 2014 | 02:52 AM
wr310rdr's Avatar
wr310rdr
I had a similar problem, turns out the steering gear box failed and the fluid was just running in a constant circuit rather then providing force to turn the wheels.
I don't know a test procedure for it, I took the old fashioned route and threw money at the problem, new pump, new lines, and finally a new box.
Old Feb 11, 2014 | 12:06 PM
jmikeyj4's Avatar
jmikeyj4
Did you replace the box yourself?
Old Feb 11, 2014 | 11:20 PM
wr310rdr's Avatar
wr310rdr
yep, over all it wasn't a complete pain.
the hardest part was getting the rusted together steering column slip joint to move back enough to get the new box in place, and then getting the lines good and tight with the fender-well still in.
I would suggest taking the fender-well out or loosening it to move it a few inches up for clearance.
Old Feb 12, 2014 | 07:33 AM
DAT2109's Avatar
DAT2109
The steering box controls how pressure is applied to the movement of the steering wheel, Replacing a steering box is rather simple, but if you go that route try to get a high quality replacement so you arnt doing this again in a month or two.
Old Feb 12, 2014 | 11:14 AM
jmikeyj4's Avatar
jmikeyj4
probably just going to start with the pump its self than go from there.
Old Feb 16, 2014 | 09:41 AM
jmikeyj4's Avatar
jmikeyj4
Hey guys replaced the power steering pump works fine now. but there is this awful screeching noise seems like its coming from the pump?
Old Feb 16, 2014 | 12:36 PM
88n94's Avatar
88n94
Did you use Type F automatic transmission fluid as your power steering fluid?
E-Works
17
Jan 6, 2020 07:42 PM
Ronnief150man
Dec 23, 2016 12:51 PM
John Thomas II
Apr 16, 2011 12:57 PM
t.Rowley
Mar 28, 2008 01:29 AM
Shawn7240
Mar 4, 2008 01:28 PM
