Numberdummy will know for sure, if you post data plate & vin.
I seriously doubt it. In fact, I'd bet money it didn't, as the 406 was a hi-po engine, and was either tri-power or 4bbl.
352s got 2bbls, 390s got them in '66 along with low enough compression to run regular to appeal to cheapskates like my dad. Even 429s got them on some of the luxobarges. But not a 406.
Someone could have put that manifold on there. Any casting numbers showing?
The short answer is NO. All 406's came from the factory with a 4 barrel manifold and carb. If you ordered the 3X2 set up it came in the trunk and was either dealer install or customer installed after delivery.
i owned the mentioned car years ago and sold it to a local farmer. before i sold it i took the vin # in too ford to get a carb # to order a carb kit and they said it was a 406. i saw the car at the farm not long ago and it still had the engine in it, i was thinking of getting the car and rebuilding the engine for my hi-boy
could a 1962 ford 4door car come with a 406 engine and a two barrel carb?
Nope, Nope and Nope !! The 406 was available in 1962 and 1963 model years, only for the full size Ford. It came in two forms...one (code B) a 385 hp with one 4 bbl. carb (Holley 600 cfm )and a (code G) 405 hp version that had 3 two bbl carbs (Holley for a total of 840 cfm).
That was it.
Not true the 406 3X2 version was rated at 920 CFM, the 390 was rated at 840 CFM. Even though it was the same identical setup, the 406's added CID let is suck more air thru the carbs.
I'm not convinced of your info. I got my info from the book, American V8 Engine Data Book (1949-1974) . BTW, the highest hp (401 hp) 390 with 3 X 2 bbl. carbs is rated at 860 CFM, not 840 CFM.
What about if some moronic poindexter swapped a 2bbl intake on? Correct me if I'm wrong, but didn't all 406's have the bosses, not necessarily drilled, for cross bolted mains? I could be thinking of the 427's though.
less, My info comes from FORD in their "Muscle Parts Story" Supplement No.1, page 32. I quote;
"INDUCTION - Factory 406's came with either 600 CFM 4-bbl or 920 CFM 6 bbl carburation. The 390 used the same 4-bbl set up, but had 860 CFM rated three duces atop."
65f100_352, Like I said before, If you didn't buy it new, who knows what some dipstick did.
Some 406's had the crossbolt bosses and some didn't. If it's a TRUE 406 block you'll see the "HP" cast into the block. Also the block casting numbers for 406's are some of the few that actually match up. Except for the 64 service block. As mentioned it'll be a solid lifter block with the oil pressure relief valve above the rear cam plug. Sure someone could have dropped a 2bbl intake on it at some point. But there are enough external clues to ID it. What heads are in it? C2SE-6090-B, C2SE-6090-C are the 2 most common heads. C3AE-6090-C's are the small chamber heads with valve spring cups. But also the 390 used a version of those in high altitude places with bigger chambers and no spring cups. All the C2 406 heads I've owned had 1.65 ex valves and 2.05 intakes. That's one thing many books get wrong. People get things set in thier mind on what they have. If I had a dollar for every 406-427 that turned out to be a 352..... What exhaust manifolds are on it? Is this something your looking to buy or just a wonderin?
Also one thing on 406 production figures.....the info is somewhat limited and unclear to what's actually out there. So I'll say never say never when it comes to Ford. If you had the money and connections anything was possible. Because you just never know. I don't care what all the books in the world say. Documentation on the 427 cars was much better but is still sorta vauge at best. Anyone ever see a 427 4 door Police car?
1962/63 full sized Ford's and Merc's could be had with 406's.
I had a '63 Galaxie 500 ragtop with one, a friend has one of the very few 1963 Ford 500XL Country Squire Station Wagons with a 406.
While a 1962 Ford fordor sedan could have had a 406, most likely it came with a 292, 352 or a 390 originally. The 223 I-6 was standard equipment.
There is exactly ONE 2V carburetor kit used on ALL 1962/74 Ford's (1962/71 Auto-Lite / 1972/74 Motorcraft) regardless of the engine size: C2AZ-9A586-B. Ford later replaced it with D4AZ-9A586-A.
Since there is only one 2V carb kit, why would a partsman at a Ford dealer need the VIN to come up with the correct kit?
And...the partsman then would have asked...if the VIN showed it to be a 406 with three deuces, do you want THREE 2V kits?
No 406 engine ever came with a 2V. Period...end of discussion.
I have all the Ford HiPo parts catalogs from 1961 thru 1968. These are not the Muscle Parts Catalogs, because they weren't available till 1969.
So if further info is required about 406's, all y'all have to do is ask.
The 406 came out mid-year in '62, as did the XL package- mine happens to be both, original paint, 80K miles. B-code is the 1x4, 385 HP, G-Code (which mine is) came with 3 dueces, 401HP. Even with the XL package, manual steering and brakes only- big drums like a cop car or wagon, but manual only. The later 406 blocks started having cross-bolt bosses cast in in '63 (I have one, bosses but undrilled). A few of the race cars even came out with 2x4's in late '62, but not an available option to purchase. Could you have gotten a 406 in a four-door? Sure, why not? Stranger things have happened from Ford. If that car had one, it could have been swapped out, manifold changed, been a long time since '62.
427 four-door Police Interceptor? Yes, I saw, and rode in, one when it was new- NY State Police. '63, 427-8V, it was the barracks "Pursuit" car. My dad was a BCI Investigator, and when his regular unmarked 390 PI got hit, it was in the body shop for 3 weeks- and he drove the 427 car in the meantime. The rest of the guys at the barracks were a little cheesed that he got to drive the "hot rod" for 3 weeks straight. White & black with a bubble-gum machine on top. Had a big spot on the hood where the paint was blistered and burned, from it backfiring through the carbs and catching fire- it went to the body shop next. Quiet exhaust, all you could hear was the carbs howling
My 406 car- it has a 427 in it right now, C-6 w/4000 converter, and 5.14 gears- the Evil Twin
