Lincoln 406 FE
Old Jan 4, 2006 | 06:46 AM
boomer202's Avatar
boomer202
Lincoln 406 FE
Anybody ever put a 406 FE in a truck? Do the 406 and 360/390 share any of the same components? I have only seen the 406 in mid 60's Lincolns...
Old Jan 4, 2006 | 06:55 AM
jowilker's Avatar
jowilker
boomer, There was a recent ebay auction of a truck that claimed to have a 406 in it. The 406 was a Nascar race engine with a few put into production to make it work for stock car racing. I don't know the total but there were never many built. All of the FEs with the exception of the side oiler look the same from the outside, or so is my understanding.
John
Old Jan 4, 2006 | 08:15 AM
BobbyFord's Avatar
BobbyFord
My dad had an early Galaxie with a 406 in it. He also put one in a 65 Mustang coupe (had to put a straight axle from an Econoline van to make it fit).
The 406 looks like any other FE from the outside, except for the cross bolts in the side of the block.
Old Jan 4, 2006 | 10:18 AM
Mike G's Avatar
Mike G
You may want to do a little more research on this one.. I think the 406 Lincoln is from the MEL engine family, similar but not related to the FE. Finding any new parts may be an issue.
--Mike
Old Jan 4, 2006 | 10:41 AM
mikeelikee's Avatar
mikeelikee
The 406 is an Fe
It is a center oiler with a 428 bore and 390 stroke. The 410 is a 390 bore with a 428 stroke. Some were used in Nascar, only the last few were crossbolted. If you have a 352 360 or 390 it will bolt in, if the motor mounts will bolt up.
Old Jan 4, 2006 | 12:31 PM
Mike G's Avatar
Mike G
Further research- The 406 is indeed an FE from the 62-63 production year. If you find one, and it's cheap, grab it! It will probably only have two bolt bosses in the motor for your motor mounts, but that's not a big deal.
-Mike
Old Jan 5, 2006 | 05:48 AM
jowilker's Avatar
jowilker
Mike, First off there were only hundreds build not thousands, and if you were to run across one, I wouldn't look for cheep at the same time. IMHO
John
Old Jan 5, 2006 | 07:46 AM
boomer202's Avatar
boomer202
Reason I asked is I know where one is. A neighbor pulled a 406 out of a 63 lincoln to put in a Merc...project never really got off the ground - both the Merc and the Lincoln have been sitting for almost a year with the motors in the garage....I may have to pay him a visit and see if he would be willing to part with the 406.
Old Jan 5, 2006 | 08:23 AM
312's Avatar
312
if he pulled it from a 63 lincoln its a 430.different engine.
Old Jan 5, 2006 | 09:31 AM
bryyce62's Avatar
bryyce62
A quick check of the number of valve cover bolts will clear this up. If it's got 5 it is an FE.
b62
Old Jan 5, 2006 | 09:34 AM
boomer202's Avatar
boomer202
Thanx for the info - I'll check it out. I didn't even know there was a 406 FE...when I was talking to the guy he was the one that told me it was a 406. But he did say that he is not a Ford guy...just happened to end up with the Lincoln and the Merc.
Old Jan 6, 2006 | 06:30 AM
jowilker's Avatar
jowilker
The Lincoln engine is different from the FE 406, and will not swap without the tranny.
John
Old Jan 6, 2006 | 08:46 AM
312's Avatar
312
the only thing the 430 has in commom with the fe is the bell,and flywheel.i helped put one in a 63 merc way back.you could put this in a truck if your handy.they use to put them in everything for the cubes.saw them in 56s .cars that is.these brutes were wall to wall.
Old Jan 6, 2006 | 01:02 PM
boomer202's Avatar
boomer202
So if it turns out the motor out of the Lincoln is a 430 then I should just stick to my 390....
Old Jan 7, 2006 | 06:36 AM
jowilker's Avatar
jowilker
ABSOLUTELY!!!
John
glassmanbruce
Oct 29, 2015 08:30 AM
sloopy76
May 3, 2013 01:05 PM
rhpope
Apr 17, 2007 11:10 PM
68 REBL
New Member Introductions
Jan 24, 2007 10:17 AM
6.9tank
Aug 15, 2004 04:04 AM
