MAP sensor
Old Feb 10, 2009 | 10:40 AM
cowmilker08's Avatar
cowmilker08
Question MAP sensor
Exactly what does the MAP do and what are the symptoms of a failing or failed MAP?
Old Feb 10, 2009 | 11:48 AM
Action4478's Avatar
Action4478
IIRC ,its used for fueling (after measuring boost) ..lack of power is one symtom ...
Old Feb 10, 2009 | 12:15 PM
NWBronco's Avatar
NWBronco
MAP Manifold Abolute Pressure. Manifold pressure measured on the absolute pressure scale, an indication of engine load. At sea level, with the engine off, MAP=100kPa (14.5 psi).
And what Rick said about lack of power.
Old Feb 10, 2009 | 12:48 PM
cowmilker08
how about loss of fuel mileage?
Old Feb 10, 2009 | 01:10 PM
NWBronco's Avatar
NWBronco
Doubtful. CEL on? You may need to get a code reader and see what the almighty management system has to say...
Old Feb 10, 2009 | 01:15 PM
cowmilker08
no cel, last i check for codes was before the drop in fuel mileage, and had a p1111 all clear. it might just be the winter fuel, but i don't know becuase last winter i got 14.5 usually, now only 13 sometimes 12.5. between last winter and this one i put a straight pipe on, K&N air filter (a week before i heard of the napa 6637), and an edge evolution chip. but these all increased my fuel mileage in the summer. before all of that it was 15.5mpg in the summer and after it was 18.5-19mpg. idk maybe its nothing.
Old Feb 10, 2009 | 01:34 PM
NWBronco's Avatar
NWBronco
If the MAP goes south you'd know it. Given that the only thing is your mileage, I'm thinking you are okay.
Old Feb 10, 2009 | 01:37 PM
cowmilker08
hmmm, well i wish i knew why my mpgs went south. the only other difference is tires and when i put then on in the summer after the other thing my mpgs only dropped by .2mpg.
Old Feb 10, 2009 | 02:40 PM
Cuda_jim's Avatar
Cuda_jim
There have been reports of mileage differences from station to station, even from the same station that received a new load in their tanks. Mileage usually goes down in the winter months.....winterized fuel additives, more/longer idling, longer times to get the engine up to temp all use more fuel.
Old Feb 10, 2009 | 03:21 PM
cowmilker08
i always buy BP at one of four locations and it is consist between them.
Tugly
May 9, 2014 07:49 AM
cowmilker08
Mar 22, 2009 11:46 PM
moritz1024
1978 - 1996 Big Bronco
15
Mar 27, 2005 10:15 AM
sinjin90
Feb 5, 2004 06:13 PM
nmaineron
Mar 8, 2002 01:07 PM
