Question on Chip / Module
Old Feb 10, 2009 | 10:23 AM
rfish84's Avatar
rfish84
Has anyone here ever used or seen one of these ?
eBay Motors: 94-03 FORD POWERSTROKE 7.3 DIESEL CHIP TUNER PROGRAMMER (item 200296965486 end time Mar-09-09 22:35:00 PDT)
Really tough for me right now to afford a DP or other premium tuner. I am wondering if this thing is or can be any good
Old Feb 10, 2009 | 10:35 AM
03_PSD's Avatar
03_PSD
I wouldn't buy it. I might be wrong but you can make that same chip yourself for under a dollar. I'll try to find the link for you.
Old Feb 10, 2009 | 10:36 AM
robs01f250's Avatar
robs01f250
I wouldn't buy it. While Glenn is looking for the link i will look to
Old Feb 10, 2009 | 10:37 AM
superduty4x4's Avatar
superduty4x4
Glorified 10k mod... search for 10k mod and you'll find tons of threads.
Old Feb 10, 2009 | 10:39 AM
03_PSD's Avatar
03_PSD
Good job Chase, I couldn't remember what the mod was called.
Old Feb 10, 2009 | 02:18 PM
Pocket's Avatar
Pocket
It's not a chip, it's an ICP mod.... or as others have called it the 10K mod. It's simply a 10K resistor inline to the ICP sensor. It tricks the PCM into thinking that the ICP pressure is too low, so the PCM commands for more pressure. The result is a little bit more power.
The horsepower and mileage claims are absolutely rediculous in that ad. Realistic gains would be more like 40 hp, and zero gains in mileage. I ran a version of this back when I first got my truck, and it's just an ok toy to play with for about a day.
The problem with this is that you are adding more power without proper tuning anywhere else. You are not adjusting fueling, timing, or any of the transmission controls. So even though this module is cheap compared to an actual chip, it doesn't do nearly as much as a chip.
Old Feb 10, 2009 | 02:43 PM
riverrat41's Avatar
riverrat41
You are smart by asking these folks here at FTE.They will not steer you wrong and it is a wealth of knowledge.
Old Feb 10, 2009 | 05:01 PM
rfish84's Avatar
rfish84
Thanks a bunch guys. Oh well, looks like i will have to keep saving for the DP Tuner then.
Do i really need gauges to go along with this DP unit ?
Old Feb 10, 2009 | 05:36 PM
superduty4x4
Do you really need gauges? If you don't tow or work the truck very hard you'll be fine without them most likely. Otherwise you're gonna want them. Even on a stock truck they are a good idea.
Old Feb 10, 2009 | 06:43 PM
JT250's Avatar
JT250
I woud say just keep saving. I always try to steer clear of the cheap and easy route. Sometimes it works, but you really have to do your homework and make sure it does before you do it. I would say yes on the gauges. If you get a high performance tuner you will, at some point in the trucks life, get the infamous "itch" to show your buddy, girlfriend, wife, or mustang owner how fast your truck really can go. At that point you will want to be able to monitor your exhaust temp at the very least.
03_PSD
21
Oct 22, 2009 04:23 PM
wiccantoy
Jun 5, 2009 07:41 AM
slowmans
May 24, 2009 09:02 AM
superduty4x4
Jan 27, 2009 10:14 AM
superduty4x4
Jan 27, 2009 01:00 AM
