Was going to see if you could tell me something about mine. I believe it is a 3.50 gear also, but want to know the rest of the code: WDM CJ 8MC 2 75 9 356A Thanks Scott
WDM-CJ = Ford 9" / 3.50-1 / non Limited Slip / 28 Spline Axleshafts.
2) D8TZ4234E .. Axle Shaft / Use with 3/8" backing plate bolts.
It was, at one time, necessay to know what size these bolts were, because 1978/79 E/F100/150 & Bronco 9 inchers came with two different sizes (the other is 1/2").
In order to get the correct rear axle internal parts, one had to know this jazz.
8MC = Assembled the 3rd week (C) of December (M), 1978 (8)
Thanks for all the help NumberDummy. When it comes to codes and part numbers and fords period you are them man. I put a post in the small V8 section with the numbers off my 302 motor. Can you help me there if you have time. Thanks
