Taller tires?
Old Feb 9, 2009 | 10:25 AM
desoto dave's Avatar
desoto dave
Taller tires?
Are right ,correct me if i'm wrong but i've read alot of treads in here and some of the sollutions for our series trucks for high reving on the highway is too install taller tires.Knowing that it brings the rpm's down,does or does not this reflect on the correct mph?so i think installing taller tires brings the rpm's down, it would mean your going slower or faster from before?so if your going slower that would mean you would have to bring up the mph,bringing your rpm's back to were ya started.or the oposite.
Old Feb 9, 2009 | 02:49 PM
Fritolay's Avatar
Fritolay
opposite taller tire means more outer surface area so less revolutions of the tire to go the same distance. The speedo will not read acurately. Mine has not worked for more than a month at a time for the last 15 years so i just always drove by feel and the tach.
Old Feb 9, 2009 | 03:06 PM
Rockstone's Avatar
Rockstone
With a taller tire, the same speed will give you lower RPM. If you run the same RPM with a taller tire, your speed will be higher.
Old Feb 13, 2009 | 07:41 PM
Ford 67 Ford's Avatar
Ford 67 Ford
An inch or so taller tire will throw your speedo of slightly, but when I switch of my 32" tall tires to my stock 28"s I feel like I'm missing a gear (having a 3 speed I feel like I'm missing one anyways).
Old Feb 15, 2009 | 03:06 AM
Big Skier's Avatar
Big Skier
Hey 67,
What was your lift to fit the 32" tires? Your truck looks great. Not to tall, not too short.
Thanks!
BS
Old Feb 15, 2009 | 05:01 AM
Fritolay's Avatar
Fritolay
my old 72 is runnin 31x10.5r15's and it is sittin stock so may not really need much of a lift if any for 32"s.
Old Feb 15, 2009 | 01:05 PM
Ford 67 Ford
Big Skier, thanks, put a 4" lift to make it look right, the 32's fit without a lift but just didn't look right.
Old Feb 15, 2009 | 03:23 PM
Ford_Six's Avatar
Ford_Six
I'm running 285/75R16s on the back of my F250, basically 33s, no lift and it's a 2wd. The front has 235/85r16s, clears them without any issues at all.
Old Feb 15, 2009 | 06:34 PM
Danger_Dave's Avatar
Danger_Dave
this is way too confusing! all i can say is i'm a motorcycle stuntrider by hobby and a smaller back sprocket will give you more top end and a bigger back sprocket will reduce your top speed but give you insane torque. i would have to believe tires are the same principle because a wheel is basically a gear or pulley just in a different form. and every gear or pulley system i have ever seen works the same. smaller input drive pulley= less speed, more torque, more rpm from the motor. larger input drive pulley= more speed, less torque, less rpm from the motor. and a smaller final drive pulley = more speed, less torque, less rpm . a larger final drive pulley = less speed, more torque, more rpm from the motor. okay now i have a splitting headache
Old Feb 15, 2009 | 06:53 PM
Talltruck's Avatar
Talltruck
Try to think of the smaller sprocket being the same as a bigger tire and the bigger sprocket being a smaller tire. With your truck you aren't making the drive gear bigger or smaller, you're changing the tire size.
Another way to think about it is how far the truck will move when a tire spins one rotation. The small tire won't move the truck as far as the big tire, even though both only spin one rotation. The engine only knows it spins the tire one rotation so bigger tire = more distance covered.
swampthang
Jan 22, 2017 02:40 AM
badmouthachevytoday
2009 - 2014 F150
Sep 13, 2015 01:40 PM
Mongrel
23
Mar 7, 2011 05:49 PM
benson az
2009 - 2014 F150
13
Oct 9, 2009 01:34 PM
86stepsideF150
17
Nov 12, 2008 09:50 PM
