Sponsored by: Auxito
Bad alternator?
Old Feb 8, 2009 | 04:16 PM
k150's Avatar
k150
Bad alternator?
driving home just now the battery light next to the volt meter lit up. Does this mean the alternator is going bad or is it just the battery. Thanks
Old Feb 8, 2009 | 04:34 PM
fordguy4life's Avatar
fordguy4life
If you have a volt meter, check what the volts are at the battery with the engine running. The alternator should be charging at darn near 14 volts.
Then check the battery when its not running. It should hold a charge.
When my alternator went, the indicator would come on when accelerating quickly.
Old Feb 8, 2009 | 05:45 PM
galaxie641's Avatar
galaxie641
Yes, most likely it is a bad alternator. It should read over 14 volts while charging but even when they go bad they can still read good volts. Getting the alternator tested is the best bet, but a lot of the "big box" auto stores have a habit of testing every alternator they see as bad.
Old Feb 8, 2009 | 05:52 PM
93RangerXL4x2's Avatar
93RangerXL4x2
My 4.2L did i replaced the alternator after i replaced the original motor craft battery.
Old Feb 8, 2009 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
original battery last about 5 years. anything over that is on borrowed time. alternators go about 150k miles. Some better , some worse. What have you got?
Old Feb 8, 2009 | 09:39 PM
k150's Avatar
k150
97 F150 5.4 Flareside ORP 129000+ miles I think I am on my third battery since 23000mi when I bought it
Old Feb 9, 2009 | 10:54 AM
fordguy4life
Wow! I have 180k on my '99 and just replaced my first battery. A good rule of thumb is 5 years though.
Old Feb 9, 2009 | 01:39 PM
galaxie641's Avatar
galaxie641
That many batteries tells me the alternator is weak and eating up the batteries or the batteries were good and the problem was misdiagnosed as a bad battery when it was the alternator. I am only on my 3rd battery now with 240K miles, first one lasted over 6 years and when I replaced my alternator I replaced the second one to be safe.
Old Feb 9, 2009 | 06:46 PM
k150's Avatar
k150
Yes it was the alternator--replaced it ..battery is fine. I did check ,it's the second battery-so thats about average...
Thanks for the input
Old Feb 9, 2009 | 10:11 PM
mtondreo's Avatar
mtondreo
It amazes me the bad luck I guess I have with my truck. 03 5.4 sc 2wd and I am on my 3rd battery and just got a new alternator a few months ago. Truck has 63k mi. It has a couple of tvs (draw hardly any current) and one sub amp. Maybe I need to stop dropping it off to get it fixed and start working on it myself again. I'm sure I could have at least salvaged the battery this last time.Glad you got it fixed though, just had to rant for a minute.
Old Feb 10, 2009 | 09:25 AM
Spotty's Avatar
Spotty
I am on the original battery that came in the truck in 1998. I have never seen a battery last this long, especially in Minnesota. My truck sits outside in all types of weather. I did change the altenator at about 120,000 miles. I got the "flicker" at higher RPM's. I think I have about 170, 000 miles on the truck. I have always used the OEM block heater when below -0, that makes a huge difference in how it cranks. Glad you got it fixed. It took me 2 or 3 alternators before I got one that did not sound like "turbo whine" when I turned on the lights. There is some real junk on the market these days.
Old Feb 10, 2009 | 09:49 AM
93RangerXL4x2
the Motor Craft battery lasted 9+ years in my 1999, 300,000+ kms on a battery lol, and a buddy of mine with 224,000kms jsut replaced his after 9 years.
Old Feb 10, 2009 | 12:36 PM
mtondreo's Avatar
mtondreo
Spotty - thx for the info. My truck has been back twice because of the whine after they changed the alternator and of they told me it was because of the electronics. Maybe I can get them to replace the altrenator now.
Old Feb 10, 2009 | 06:47 PM
Spotty's Avatar
Spotty
Yeah... do not accept that. I took back 2 of them to NAPA, they finally gave me a Delco, it is as quiet as the OEM was all those years. They told me it was normal under load for them to whine. I brought the guy out to the truck and had him sit in it. That was all it took. I mean it whined so loud it sounded like I was running a blower set up about 2 feet out of the hood. If they give you any grief have them listen to one that still has the OEM altenator. I'm just sick of junk being marketed as top notch in many situations...Rant over... By the way... Best of Luck...
Jeff
pgf50
29
Jun 13, 2016 03:39 PM
jcd
Mar 24, 2016 02:36 PM
Pikachu
18
Dec 21, 2009 08:26 PM
scott7512
Apr 24, 2007 11:12 AM
duden123
Sep 10, 2006 12:32 PM
