Cross member torque spec
Old Feb 8, 2009 | 11:03 AM
cscott952's Avatar
cscott952
I am experience the creaking issue others have mentioned. It comes from the middle of the truck, so I'd like to check the torque of the frame cross member, but I don't know what the spec is. My repairs books don't give it. Does anyone know what the cross member bolts should be torqued to?
Old Feb 8, 2009 | 12:08 PM
quicklook2's Avatar
quicklook2
nut, crossmember no.1 =139-141 lb ft
bolt crossmember no. 4 =25-34 lb ft
nut crossmembers no. 2,3,4,6 and 7 (where required) =44-70 lb ft
these are from ford service manual.
Old Feb 8, 2009 | 12:49 PM
cscott952's Avatar
cscott952
Can you explain the numbering? Does that mean there is a different torque level for some bolts of the same crossmember?
Old Feb 8, 2009 | 01:05 PM
quicklook2's Avatar
quicklook2
no drawing to explain where number 1 is, find the one with only bolts as close to the front of the vehicle as you can and then count back to 6 or 7 crossmembers.
follow what i wrote.
no. 4 has both bolts and nuts.
i am not getting under my truck in the snow so i hope i have given you enough info.
lpdcjr
Aug 19, 2014 08:19 PM
78ford351m
17
Mar 14, 2012 08:19 PM
Screw that
Dec 11, 2011 04:52 PM
Rubidon
Nov 21, 2008 10:33 AM
AustinV10
Sep 22, 2004 07:36 AM
