Sponsored by: Real Truck
Differential torque specs
Old Sep 15, 2004 | 04:00 PM
AustinV10's Avatar
AustinV10
I am changing the differential seal on my 99 f250 SD supercrew and I don't know what the torque specs are on the large nut? Any help would be appreciated.
Old Sep 15, 2004 | 09:21 PM
99f350sd's Avatar
99f350sd
µ 3. Install a Nm (inch-pound) torque wrench on the pinion nut, and record the rotational torque required to maintain rotation of the pinion through several revolutions.
µ 4. CAUTION:
After removal of the pinion nut, discard it. A new nut must be used for installation.
Use the Flange Holder to hold the pinion flange while removing the pinion nut.
µ 5. Mark the pinion flange in relation to the drive pinion stem to ensure proper alignment during installation.
µ 6. Use the 2-Jaw Puller to remove the pinion flange.
Installation
1. Lubricate the pinion flange splines.
l Use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
µ 2. Note:
Disregard the scribe marks if a new pinion flange is being installed.
Align the pinion flange with the drive pinion shaft.
µ 3. With the pinion flange in place in the rear axle housing (4010), install the pinion flange using the Companion Flange Replacer.
µ 4. Position the new pinion nut.
µ 5. CAUTION:
Under no circumstances is the pinion nut to be backed off to reduce preload. If reduced preload is required, a new collapsible spacer and pinion nut must be installed.
Use the Flange Holder to hold the pinion flange while tightening the pinion nut.
l Tighten the pinion nut, rotating the pinion occasionally to make sure the cone and roller bearings are seating properly. Take frequent cone and roller bearing torque preload readings until the original recorded preload reading is obtained by rotating the pinion with a Nm (inch-pound) torque wrench.
l If the original recorded preload is lower than specifications, tighten to the appropriate specification for used bearings. If the preload is higher than specification, tighten the nut to the original reading as recorded. Refer to Torque Specifications in this section.
µ Refer to corresponding illustration.
6. Install the driveshaft. For additional information, refer to «Section 205-01».
7. Install the brake calipers. For additional information, refer to «Section 206-04».
Old Sep 22, 2004 | 07:36 AM
bmfzo6's Avatar
bmfzo6
hi what size socket do you use on the pinion nut on an 2001 f350 with the i beleive a 10.5 rear end thanks
green_95
Jun 17, 2016 12:37 PM
Benchwrench
May 11, 2016 02:45 PM
DevilDog0402
Escape & Escape Hybrid
Sep 3, 2011 08:34 AM
spdjunke
May 27, 2004 09:15 PM
Superdave
Aerostar
Mar 15, 2000 12:04 AM
