Voltage Reg
Old Feb 7, 2009 | 10:48 PM
skunktruck's Avatar
skunktruck
Question Voltage Reg
Hi,
So how would i know if the voltage reg is bad? The reason I ask is my fuses seem to be getting 14.30 volts w/eng running to me it seems high, tho I dont check that part of the truck alot so i cant remeber LOL. All i wanted to do was hook up the choke to the reg. and that whole 14 pluse seemed way to high for a electric choke correct?
thanks
Old Feb 7, 2009 | 11:06 PM
donjamer's Avatar
donjamer
Originally Posted by skunktruck
Hi,
thanks
14.3 volts sounds right to me... When the alternator is running you get the voltage above 12 volts..
The voltage regulators job is to maintain a constant voltage.. If the voltage is fluctuating up and down then I would suspect that..
You should be fine with the choke..
Old Feb 7, 2009 | 11:13 PM
skunktruck's Avatar
skunktruck
ok i was worried that anything over 12 was bad at the fuses. as for the choke it seems like the ground is getting very hot!!!
Old Feb 7, 2009 | 11:18 PM
fmc400's Avatar
fmc400
MSEE
The choke needs to run from the stator terminal of the alternator. It's marked with an 'S'. It's a 14 volt AC three phase signal. If you put your DC meter on it, it shows up at about 7 volts RMS. This is fine. You want to use this signal because it's only hot when the motor is turning.
Old Feb 7, 2009 | 11:26 PM
skunktruck's Avatar
skunktruck
ok see it was hooked up there and of course it said 7 volts, and I laughed and said no you need 12 volts sigh so i should redo that?
Old Feb 7, 2009 | 11:38 PM
fmc400's Avatar
fmc400
MSEE
No, you shouldn't. It's not saying 7 volts because anything is wrong. It's saying 7 volts because it is not a DC signal. It swings from zero volts to 14 volts, with many slopes in between. When you set your meter to DC and read it, it sees the low frequency components of the signal, which sit around 7 volts. You don't need to rewire anything; it's supposed to be this way. This is more than enough to heat up the choke. It came from the factory this way.
Old Feb 7, 2009 | 11:41 PM
skunktruck's Avatar
skunktruck
ugh ok tomorrow i better redo it, lol
thanks alot
Old Feb 7, 2009 | 11:44 PM
fmc400's Avatar
fmc400
MSEE
thanks alot
I said not to change the factory wiring...unless I'm reading your post wrong? If you're saying you already changed it, then yes you need to switch it back to the factory setup.
Old Feb 7, 2009 | 11:48 PM
skunktruck's Avatar
skunktruck
it was ran from the ALT this morning, and as i said i cut it and reconnected it to the volt reg. so if i understsnd correctly it needs to run from thr alt. correct?
Old Feb 8, 2009 | 09:41 AM
fmc400's Avatar
fmc400
MSEE
You need to undo what you did, and return it to the original factory setup. Disconnect the negative battery cable while you're working, and reconnect it while you're done.
In the future, ask questions first, cut wires later. You've essentially caused a lot of frustration for yourself over something that wasn't even wrong. "If it ain't broke, don't fix it"
horton
Large Truck
Mar 28, 2013 08:37 AM
clydesride
2009 - 2014 F150
Nov 11, 2012 11:44 AM
2xcrash
Nov 8, 2008 10:23 PM
86rustbucket
Mar 13, 2008 06:41 PM
jonnycarr
1978 - 1996 Big Bronco
Sep 26, 2000 02:33 PM
