390 won't start
Old Feb 7, 2009 | 09:26 PM
75_f250_highboy's Avatar
75_f250_highboy
390 won't start
Hey guys, I just finished putting the top end of my 390 back together in my 75 f250 after a valve job. The truck will crank and finally start but only run for 10-15 seconds, while running it's very smooth and revs nicely. I replaced the ignition coil and it still has the problem. Any help would be appreciated.
Old Feb 7, 2009 | 11:00 PM
Putt's Avatar
Putt
Check ignition timing, check fuel quality and quantity at carburetor.
How long was it apart while you had the valve job done?
Old Feb 8, 2009 | 01:35 AM
Bear 45/70's Avatar
Bear 45/70
Sounds more like it's not getting enough fuel to stay running, rather than an ignition issue.
Old Feb 8, 2009 | 08:56 AM
75_f250_highboy
It was apart for about 3 months, I can rev it easily for about 10 seconds and then it just stops.
Old Feb 8, 2009 | 10:26 AM
Putt's Avatar
Putt
Check the fuel delivery system as well as the fuel condition. Todays fuel varnishes very quickly, it might have gummed up the carb or fuel pump causing little fuel getting to the engine.
Old Feb 8, 2009 | 10:57 AM
75_f250_highboy
will do, thanks guys
75explorerxlt
15
Feb 27, 2023 12:13 PM
BelJask
May 3, 2016 06:19 PM
mean351stang
Jan 17, 2016 11:58 AM
cstempert
Aug 1, 2015 02:12 PM
mdog1596
Jan 17, 2010 03:38 PM
