Alignment Spec question
Old Feb 7, 2009 | 09:15 PM
Ford Fx4's Avatar
Ford Fx4
Question Alignment Spec question
I Am having some trouble with my truck pulling hard to the right. I had my truck checked and this is what the read out said.
BEFORE
-----------------LEFT--------- RIGHT
CAMBER .............. -0.4............ -0.7
CASTER................. 4.2........... 4.5
TOE.................... -0.18.............. 0.04
TOTAL TOE -0.14
STEER AHEAD -0.11
REAR THRUST ANGLE 0.25
According to what the guy told me and the print out said my left toe was in a bit and the steer ahead was out a bit also.
AFTER
CAMBER.............. -0.4.............. -0.7
CASTER.............. 4.2.............. 4.5
TOE................. 0.00.............. 0.01
TOTAL TOE 0.01
STEER AHEAD -0.01
REAR THRUST ANGLE 0.24
Everything is now in the green on the print out.....but the truck still pulls hard to the right. I am almost certain it is a tire issue but just want to rule this out.
How do the specs look?
Also, Anyone know the factory specs for my truck?
Thanks
Old Feb 7, 2009 | 11:24 PM
m-mavar's Avatar
m-mavar
4WD SuperCab
Caster a 4.4° ± 1.0° 4.8° ± 1.0° -0.4° ± 0.75°
Camber -0.2° ± 0.75° -0.2° ± 0.75° 0.0° ± 0.75°
Total toe (front) — — 0.15° ± 0.20°
Total toe (rear) — — 0.0° ± 0.20°
Thrust angle (rear) — — 0.0° ± 0.30°
Old Feb 8, 2009 | 08:05 AM
silver05fx4's Avatar
silver05fx4
the specs seem to be on, did you try rotating the tires and check front end for wear?
Old Feb 8, 2009 | 01:17 PM
Ford Fx4's Avatar
Ford Fx4
As for the tires yes,
had the right side rotated, front to back, no change.
had the left side rotated, front to back, no change.
Shop put 4 new tires on, no change, still pulls right
I know it seems unlikely to have two bad sets of tires but I have seen it before. My dad had a 05 FX4 pulled hard to the right, ford tired 5 sets of tires (bf Goodrich), checked alignment two times and it still pulled hard.
I still think it is tires. With the old tires (still had over half thread left) truck drove straight as a arrow. Next day get new tires and it pulls hard to the right.
How would I go about checking the front end for wear? I only have 22k on the ticker so I think it should all be good and tight but ya never know I guess.
Thanks
Old Feb 8, 2009 | 04:23 PM
Greg B's Avatar
Greg B
If it were my truck, I'd want a little more positive caster on the driver side than the passenger side. The camber lead looks good. I generally always tried to get approximately 1/4 degree more positive caster on the driver side to compensate for the crown in the road. That being said, try rotating the front tires side to side to see if that changes anything. If it does, it's most probably a tire issue. If not, it's an alignment issue.
Greg B
Old Feb 8, 2009 | 04:24 PM
silver05fx4
i know when i did alignments i would set them a little to the left for road crown ..and the road your testing on is flat and stright ?
Old Feb 8, 2009 | 04:28 PM
Ford Fx4's Avatar
Ford Fx4
Yes, road is flat and straight. I travel it every day for work and before with the old tires I could take my hand off the wheel and it would go like an arrow til the road turned, which is a good 1/3 mile if not a 1/2 mile.
Now I got about 2-4 seconds before I am in the ditch, its that bad.
Any Idea on what to look for on the front to make sure it's all good?
Old Feb 9, 2009 | 09:33 PM
Ford Fx4's Avatar
Ford Fx4
Originally Posted by m-mavar
4WD SuperCab
If that is the correct factory specs on TOE, Then mine are way off at 0.00 and 0.01?
RIGHT?
Thanks
Old Feb 9, 2009 | 11:22 PM
Flying_Dutchman's Avatar
Flying_Dutchman
Ive got an alignment spec sheet that shows Total toe as a different measurement. It shows the specified range as -1/32" to 11/64", its not shown as a degree measurement.
Old Feb 10, 2009 | 06:03 PM
stanger_missle's Avatar
stanger_missle
After ruling out the tires, could the brakes or bearings be the culprit?
I had a 1980 Toyota Celica once (my first car). It had a similar issue. It ended up being the caliper siezed and the pad was dragging on the rotor.
Old Feb 10, 2009 | 09:39 PM
Ford Fx4's Avatar
Ford Fx4
I thought about that also. Don't think it's a brake pad as I check all the wheels after driving for about 30-45 mins and none were excessively hotter then the others.
regret
36
Jan 13, 2017 06:59 PM
Husky44
Oct 2, 2014 05:57 AM
IslandBlueV10
Sep 17, 2013 11:11 PM
jaciii
Dec 23, 2001 08:25 AM
