Steering Wander - alignment specs
Old Dec 18, 2001 | 08:20 AM
jaciii's Avatar
jaciii
[updated:LAST EDITED ON 18-Dec-01 AT 09:21 AM (EST)]Hey all,
My v10 4x4 X was wallowing in the road like a pig. It was hard to initiate a correction and then the front end took off ahead of the steering wheel requiring counter correction. It was wearing me out.
I decided to try an alignment. I reported a lack of 'return to center' feel to the tech as the reason for suspecting the alignment. He found a SLIGHT toe error (.01deg out of spec.). All the toe readings were on the positive side of the spec range and he moved them to the negative side.
Makes sense. I won't say the truck no longer requires input, but correction is minimal now and it is difficult to OVER correct. The wheel just sits in the middle of travel - anything bumps her off course and a little pressure to the other side and she's back true. Two finger highway drivin'! Just like that ol' '75 Merc I once had!
--------------------spec---------------------Left-------Rt
camber*******-0.8 to 1.3**************-0.1********0.0
caster*******1.5 to 5.5****************3.3********3.3
toe**********-0.11 to 0.14************-0.03******-0.04
***********************FRONT
-------------------------spec-------------Actual
Cross Camber***-1.0 to 1.0********-0.1
Cross Caster***-1.0 to 1.0*********0.0
Total Toe******-0.22 to 0.28******-0.07
Your obedient servant,
JACIII
2000 X 4x4 Ltd V10
Old Dec 19, 2001 | 11:14 AM
Hiexcur's Avatar
Hiexcur
I had the same problem with my excursion....I change the shocks and the problem went away. ranch 9000
Old Dec 20, 2001 | 07:58 AM
jaciii's Avatar
jaciii
Been thinkin' about those Ranchos. Are they noticably stiffer that the stock shocks or are they just plain better all around?
JACIII
Old Dec 20, 2001 | 02:22 PM
Hiexcur's Avatar
Hiexcur
It made the truck feel more stable. With the full adjustment you can dial them in to what ever you want.
Hiexcur
Old Dec 20, 2001 | 04:08 PM
jaciii's Avatar
jaciii
I'm gonna put that on the list right after 'Brush Guard' !!
:-X12
JACIII
2000 V10 Excursion Limited 4x4 Green/Tan 4.30 gears
Old Dec 22, 2001 | 06:29 PM
qniska's Avatar
qniska
There is a fix for this, it requires replacement of the upper ball joints. I had it done to my Excursion and it helps alot
Good Luck and merry xmas
Old Dec 23, 2001 | 08:25 AM
jaciii's Avatar
jaciii
fastang50
Jul 25, 2025 05:56 AM
Onesprint
Nov 27, 2017 10:07 PM
IslandBlueV10
Sep 17, 2013 11:11 PM
X-70STANG-F150
Sep 4, 2011 10:04 PM
howarda
Sep 25, 2006 10:36 AM
