360vs390firing order
Old Feb 6, 2009 | 09:57 PM
boxer.fan's Avatar
boxer.fan
Do the 360 and 390 have the same firing order? If not how do you tell the difference?
Old Feb 6, 2009 | 10:01 PM
jimlj's Avatar
jimlj
They are the same
Old Feb 15, 2009 | 11:21 AM
old76er's Avatar
old76er
Firing order for 255 (4.2L), 302 (5.0L), 360 (5.9L), 390 (6.5L), 460 (7.5L). ALL THE SAME ORDER Distributor rotation counterclockwise 1-5-4-2-6-3-7-8
Old Feb 15, 2009 | 11:52 AM
1974SuperCabF250's Avatar
1974SuperCabF250
Counterclockwise is the thing to remember. A friend of mine is a chebby guy, but the one ford he has (an f100 w/ 360) he put new spark plugs and wires on and couldn't figure out why it wouldnt run. the firing order was right, but it was wired clockwise.
Old Feb 15, 2009 | 09:56 PM
orich's Avatar
orich
All early GM #1 cyl was on the driver side not like a ford fe left side..
orich
Old Feb 15, 2009 | 10:37 PM
Bear 45/70's Avatar
Bear 45/70
orich
I was under the impression that the drivers side was the left side. Fords number 1 cylinder is on the right side, AKA the passenger side.
Old Feb 15, 2009 | 11:02 PM
orich's Avatar
orich
When doing a tune up your not sitting in the drivers seat.So while looking at the motor ford= #1 leftside GM #1 rightside=driverside
orich
Old Feb 15, 2009 | 11:51 PM
Bear 45/70's Avatar
Bear 45/70
orich
Look boy, you are not the center of the universe. All references to the vehicle are referenced from the drivers seat, ALWAYS. The left side of the car is alway the left side of the car. Your total lack of any real knowledge of the automotive industry just came scream out into the light. FYI, this also applies to airplanes, boats, motorcycles and on and on and ....................
Old Feb 16, 2009 | 09:00 AM
orich's Avatar
orich
Gee if i don't cross every T and dot every i you bring out the text "reference" book on me. For my lack of text book statement info as noted facing the motor..Us old school guys will die this way.
orich
Old Feb 16, 2009 | 12:59 PM
Bear 45/70's Avatar
Bear 45/70
It is NOT tech book stuff. This is every day life stuff. The left side of the car and anything in or on the car doesn't change it's reference because you move and/or change your prospective. The left side is always the left side whether you are in front, back or standing on your head. Instead of learning you're arguing which means you won't learn. People like you are why bad info is still floating around.
Old Feb 16, 2009 | 05:18 PM
orich's Avatar
orich
Look boy, someone has to do it, so i'll take the credit for all of it and let you correct my bad miss leading statements that, I have posted or will post.
This will be fun. Gee, I'm just and old country boy that some people want to tell me that they know better and learn there ways... But i'll just stay in my little "center of the universe", Thanks, I kind of like that statement..
old boy orich
Old Feb 16, 2009 | 06:21 PM
cheez67's Avatar
cheez67
the #1 plug is always the plug closest to the front of the engine
Old Feb 16, 2009 | 08:49 PM
Bear 45/70's Avatar
Bear 45/70
old boy orich
You better have been collecting Social Security for real long while to call me boy. I've been both a city boy and a county boy in my life and incorrect is always incorrect, city, country or anywhere else. I seem to never learn one lesson though, "Never argue with an idiot, as they will pull you down to their level and beat you with experience."
Old Feb 17, 2009 | 10:07 AM
1974SuperCabF250
Not necesarily. The #1 can be wherever you want it to be, depending on the position of the distributer...
Old Feb 17, 2009 | 10:50 AM
Bear 45/70's Avatar
Bear 45/70
The number #1 cylinder has nothing to do with the distributor, position or rotation. It is about engine design layout. And in the automotive industry, world wide, the cylinder closest to the front of the engine is always NUMBER 1.
