Clunk from front end
Old Feb 6, 2009 | 07:41 AM
rb8484's Avatar
rb8484
I have a clunk noise coming from my front end. I notice it on bumps, which most michigan roads feel like a rough dirt road!!! Even at real low speeds of 5 mph you can hear it.
Any suggestions??
The ball joints were just replaced, I did one wheel baring last summer, the other one I checked out yesterday and looked good. Tie rods look good.....what else could it be?? I was thinking maybe one of the shocks, but it dont really sound like that.
Old Feb 6, 2009 | 08:12 AM
ttb29's Avatar
ttb29
Yep sway bar links!
Old Feb 6, 2009 | 08:15 AM
rb8484's Avatar
rb8484
Originally Posted by ttb29
Yep sway bar links!
Thanks!! That sounds pretty cheap to fix.....i hope!
Old Feb 6, 2009 | 08:17 AM
rb8484's Avatar
rb8484
So I can go to the parts store and tell them i need sway bar links??
Old Feb 6, 2009 | 08:19 AM
rb8484's Avatar
rb8484
Dang.....$55 for one!
Old Feb 6, 2009 | 11:12 AM
BAJI26's Avatar
BAJI26
Physically check the links and the bushings!
Old Feb 6, 2009 | 11:15 AM
rb8484's Avatar
rb8484
You bet i will check them before I buy. I just have to wait until the wife gets home so she can watch the baby and then i can check them.
I bet that is what it is though.
I will know shortly!!
Old Feb 6, 2009 | 11:49 AM
ExcursionDad's Avatar
ExcursionDad
I'd also check the clearance between the rubber bumpers above your front leaf springs and the frame. When I first got my X there was only about a 1/2 inch of clearance and I swear the suspension was bottoming out over the slightest of road imperfections. I ended up replacing front and rear leaf springs with F250 springs mostly because of towing issues but that made the clunk go away. Excursion springs are known for being weak and do tend to give up some clearance over time.
Old Feb 7, 2009 | 09:11 AM
ttb29's Avatar
ttb29
One way you can check to see if it's the sway bar links is to take them off and drive the truck to see if the sound goes away. Thats what I did before I bought them. I have had two trucks with the same sound and both need new links. I hope this work for you.
Old Feb 7, 2009 | 09:18 AM
ttb29's Avatar
ttb29
if you go to direct ford parts. com a little cheaper. I would stay away for the aftermarket part houses not same thing. just my 2 cents
Old Feb 7, 2009 | 09:22 AM
vettdvr's Avatar
vettdvr
Blown shock
Sway bar end link/bushing
Spring stop bumper
Old Feb 7, 2009 | 09:28 AM
cbradford's Avatar
cbradford
One thing that I have not seen mentioned is a body mount, so also check your body mounts the front seem to be more of an issue
quakerj
Nov 3, 2014 07:46 PM
Walleye Hunter
Jun 1, 2014 03:41 AM
rednekrebel28
20
Dec 29, 2010 07:45 PM
