DP question...
Old Feb 6, 2009 | 07:01 AM
Brown Falcon's Avatar
Brown Falcon
Question DP question...
Is the outlet of the 3" downpipes 3" ID or OD? I'm just wondering which adapter I'm gonna need to go from the DP to my 4" under the truck when I do it.
Also, how far back does the DP go? Does it end in front of where the stock bolts/flange is? or behind?
Old Feb 6, 2009 | 09:42 AM
Neal 97 250's Avatar
Neal 97 250
IIRC inside dimension. I could be wrong though
The DP comes down and ends where the cat begins.
Old Feb 6, 2009 | 10:05 AM
Butch(OH)'s Avatar
Butch(OH)
Usualy (note use of disclaimer word right off, LOL) an exhaust system will be designed so that the discharge end of pipes fits inside the inlet of the next unit. In other words your down pipe will fit inside of the next pipe towards the rear. Your next piece will need to be swaged out to slip over the 3" pipe of your down pipe. Mine DP is a 3" no kitty type and ended right where it would have fed it. Make sure you have the kitty elimenator type if you are not planning on using one.
Old Feb 6, 2009 | 11:20 AM
Neal 97 250
I had a DP that was made for a cat. It ended with the round swivel type of fitting. I cut the end off the cat to adapt it.
They also make a DP like I have now that is just a straight pipe.
Old Feb 6, 2009 | 11:37 AM
Brown Falcon
I already have a cat delete. I was looking at the MBRP 2 piece downpipe. I might just have to wait till i get the DP here and in the truck and then figure out if I'll need more pipe or not.
Right now I have the 3.5" stock pipe cut back behind where the cat was then into 4" pipe into a 90* to my 5" stack piping.
Old Feb 6, 2009 | 11:51 AM
Neal 97 250
You are probably correct. I had to add a 1" piece of pipe to my exhaust to make it long enough.
Old Feb 6, 2009 | 12:12 PM
Brown Falcon
the adapter to my 4" should be 6 inches long roughly... probably should have a piece of extra 3" just in case
peglegger
Feb 27, 2011 11:50 PM
Intense_Spence
35
Jan 25, 2009 04:23 AM
74baja
15
Dec 16, 2008 03:36 PM
TNT in Round Rock
Mar 23, 2007 09:03 AM
resqdawg3
Jul 7, 2004 10:13 PM
