Sponsored by: Real Truck
05S28 - Speed control system mod
Old Feb 5, 2009 | 10:35 PM
aphotic26's Avatar
aphotic26
I checked my mail and ford has notified me that:
"05S28 - Speed control system modification"
I read some things about it, something about cruise control or master cylinder lines i'm not sure.
Can someone please explain to me what a speed control system mod is and why they recalled it, my research on the net has lead me to dead ends.
Thanks
-Matt
01 F250 5.4L SD
Old Feb 5, 2009 | 10:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a brake pressure switch on the master cylinder that is used by the speed control. Sometimes the switch seeps brake fluid. This shorts the switch, which is always powered, even key off. The combination of brake fluid and heat from the short circuit has caused several fires.
The fix is to install a fuse in the circuit. It took less than 15 minutes to have mine done without making an appointment.
Old Feb 5, 2009 | 11:17 PM
aphotic26's Avatar
aphotic26
Great thanks mark!
pawpaw
1983 - 2012 Ranger & B-Series
15
Mar 30, 2018 11:46 AM
FordFamily92
May 18, 2016 11:20 AM
portsample
Jan 2, 2012 02:37 AM
Roadkingjdl
Jan 14, 2008 04:42 PM
