Ranger Cruise Control Recall
FINALLY, Ford has expanded the cruise control recall notice #05S28, to include Rangers.
Seeing as how our Rangers have the troublesome brake master cylinder cruise control deactivation switch, that likes to catch fire, I disconnected mine two years ago, waiting for them to get around to recalling Rangers.
I confirmed mine is now on the list, by checking my "My Ford" web site Ranger home page.
I suppose there will be mail notification too, but I don't think I'll wait for it, as we can schedule service on line now.
If any are curious to know if your Ranger is on the list, you could go to the "My Ford" owners web site, register, enter your Ford vehcles VIN # & notification will show up on the vehicles home page.
Lots of other useful things there too, like a link to down load owners manuals, service schedules, Dealer service specials, ect, so check it out.
Well as I understand it, this latest expansion of recall 05s28 covers Rangers between 98-02. Edit: http://www.msnbc.msn.com/id/20111687/
BUT I've read that Rangers built between 95 & 03 have the questionable cruise control deactivation switch.
The way to tell if you have the probem part, is to inspect the color of the center insulator, where the unfused & always hot power lead connects, if the color is rusty/red, you have the problem part.
So if you don't want to risk a fire, disconnect & tape over, the power leads open end, or replace the switch with one with a black colored insulator & keep the receipt for a refund, in case the recall is expanded to cover your year/ model vehicle.
My 94 Taurus has the red insulator type switch, so I'm waiting to see if it'll be included in the recall.
There's already a thread on this subject:
Forum: Newer Light Duty Ford Trucks 1997-2003 F150
Thread: Ford recalls 3.6 million vehicles
Post #1 has all the affected vehicles listed.
If your vehicle isn't listed, it may be because your switch is a different design, and not affected by this recall.
I just got a recall notice this evening on my 1997 SC Ranger! I haven't checked whether it has the red insulator yet, but I have over 200,000 miles on it so I may go out to the garage and check it and maybe unplug it. This is on the brake master cylinder,right?
TIA if anyone is still following this thread.
Tom
Tom
Yup it's the switch sticking out horiz on the very end of the brake master cylinder.
I finally got my paper work to have the recall done Aug 08.
BUT my paper work said Ford Wouldn't replace the switch unless it was showing signs of leaking brake fluid.
If it wasn't leaking, they would only install a fused wiring harness.
I elected to have them replace the switch anyway, as it's the root cause of the danged fire problem & recall & the fused wiring harness alone is just a legal band-aid imo!!!!
As my switch wasn't showing any signs of leaking, I had to pay for a new switch, but they didn't charge labor to install it.
I feel a whole lot better having a new switch & the fused wiring harness, as that switch wire is hot all the time, even when the vehicle is shut down. So without a fuse, it's just a problem waiting to happen, it should have had a danged fuse or CB all along!!!!
More thoughts to ponder.
Yeah,dang it!
Ford has also discontinued the almost bullet-proof 3.0 Vulcan in the Ranger. I can't get the options that would coax me to buy another new Ford. What ARE they thinking? I'll not be force-fed a truck that won't measure up to the Edison NJ built 4.0 SVT optioned XLT SC Special Order Ranger I have now.
This week-end I'll cut and solder a in-line fuse into my not-leaking red cruise switch wiring hot side,2 amp. This is a bit smaller truck than I work on through the week,but I think I can handle it.
What I do.Southern Indiana Body Works, Inc. is the leading truck collision repair and truck painting facility in the southern Indiana, northern Kentucky & southern Illinois areas. For commercial body work including truck collision repair, truck painting, truck
BUMP
Update, a link to the 05S28 Cruise Control Brake Deactivation Switch Recall TSB. http://www.revbase.com/BBBMotor/TSb/...dPdf?id=151063
BUMP
Thanks
