Expedition 895 lb. Tongue Weight Limit
well if you assume 15% yes it limits you to 6k, but if you go with 10% which is still in you window then you're good to almost 9000. i don't see any problem with that especially with equalizer and sway control. assuming you know how to drive, driving that setup will never be problem.(not even suggesting you don't)
gpineau,
Your '05 Expy is 12 years old....how worn out and/or corroded are the hitch and where it attaches to the frame?
BarnieTrk
Questions on limit
2012 expedition xlt, HD tow package. Picked up a 2005 chaparral 236 sunseta, Phoenix trailer dual axle with surge brakes. Trailer is 5800 lbs boat is rated at 4400...seems high. What would my tongue weight be? Anyways, towed it home 150 miles with no issues. Truck is level and brakes and starts off the line fine...I won't be buying a new truck however for towing so if I can bump up towing capacity, is there a way? Thanks
BPCheeta
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-09-2017 12:59 PM
keyul
19
03-28-2017 03:22 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
02-17-2017 01:08 PM
Torklift Sheryl
12-19-2016 03:26 PM
