Trailer Harness Plug
Old May 15, 2022 | 09:18 AM
sohcmike's Avatar
sohcmike
4wd Low
Hey guys
i bought a 96 F250 and the seven pin trailer plug has been removed. I bought a harness from etrailer but can’t find the old wiring harness on the truck. There are two plugs hanging near the back bumper. Is that where the factory trailer harness plugged into? Can’t believe that I would have to cut into a factory harness and splice wires for this to work. Thanks for the help.
Old May 16, 2022 | 05:30 AM
senix's Avatar
senix
that is probably the location. has been for years. The harness they sold you will not plug in there?
When you bought the 7 pin, did you enter your truck/model/year?
You could try the parts dept. at your ford dealer and see if they can look up the wiring and maybe that will tell you too.
Old May 16, 2022 | 07:43 AM
SpencerPJ's Avatar
SpencerPJ
A simple meter or test probe can be your friend. If that has been hanging in the elements, a good cleaning probably would be a good idea.
Old May 18, 2022 | 01:29 PM
sohcmike's Avatar
sohcmike
4wd Low
Nobody sells a plug and play. Does dealer doesn’t carry it. I was trying to keep from cutting wires if I could find a plug in harness.
Old May 26, 2022 | 08:37 PM
Tumbleweed1972's Avatar
Tumbleweed1972
Those two plugs are for the trailer wiring if I remember right. You can go to a junk yard and pull off a factory 7 pin harness or you can probe the wires and just wire yours in solid.
dpbrowne
1997 - 2003 F150
Jun 1, 2009 08:29 PM
EMD_DRIVER
Nov 7, 2008 09:22 PM
NJF350SD
Electrical Systems/Wiring
Jan 30, 2008 08:31 PM
FordTrucksKickGM
Jan 5, 2008 01:59 PM
termyt00
Oct 15, 2004 06:01 PM
