Diesel starting problems
Old Feb 6, 2009 | 09:34 PM
  #31
jdecker88's Avatar
jdecker88
Do not get autolites, get on ebay and look of some motorcraft GPs.
  #32
F350-6's Avatar
F350-6
Originally Posted by Mike2211
k i got a good grasp now so also is there a valve cover gasket i should be buying with my glow plugs?
No, it's a rubber type gasket. Very rare for those to go bad. You can ohm the pins in the pass thru connector, and a visual inspection of the gasket will tell you if there are any issues, but I've pulled the valve cover on probably a dozen trucks and never had to replace a gasket yet.
Old Feb 7, 2009 | 01:21 PM
  #33
Mike2211's Avatar
Mike2211
k i did the ohm test at 20k on the passenger side firewall to front end i got .05, .37, 2.55 and a no read nothing showed up on the tester. and on the driver side firewall to front end i got no read all three of them and -0.00 on second one from the front. i changed the 20k to 200k and 2m to see if anything was going on got nothing so please guys help me out tell me what this stuff means if you can i did the test at about 1:45 pm at probably 42 to 48 degrees a little windy but had good connections. thanks all
Old Feb 7, 2009 | 07:12 PM
  #34
SkySkiJason's Avatar
SkySkiJason
I buy everything like that from powerstrokeshop.com. Best prices and fast shipping.
I 2nd there's usually no need to change VC gaskets. I did changed the under valve cover harnesses 'while I was in there' since they were only about $26 each (powerstrokeshop). I had the problem with connector coming loose (fixed it the way Chris described earlier) and figured it was good preventative maintenance since my rig had 240k at the time. The 'new' harnesses come with a much better clip design, so no 'rigging' was necessary.
Old Feb 7, 2009 | 07:39 PM
  #35
Mike2211's Avatar
Mike2211
k any one have any input on my my ohm test form earlier post up two form this one??? thanks guys
Old Feb 7, 2009 | 09:06 PM
  #36
F350-6's Avatar
F350-6
Sounds like you have only 1 good glow plug. I'd suggest going ahead and change all 8. You've just performed the same test the mechanic did to determine you had faulty glow plugs. It wasn't really that hard to do was it?
Changing glow plugs is the same way. Intimidating at first, but after you've done it, you realize it wasn't really that bad.
Old Feb 8, 2009 | 12:31 PM
  #37
Mike2211's Avatar
Mike2211
what does it mean in the ohm scale when it doesn't read or is under the .6 guide line you guys tell me for min. resistance i obviously see one of the plugs was bad by the 2.55 reading but i had a hole side have almost no read and th eone that did read gave -0.00 any clarification would be helpful thank you
Old Feb 8, 2009 | 12:37 PM
  #38
tjc transport's Avatar
tjc transport
i ain't rite
a high ohms reading will mean a connection is broken in the plug. a .000 reading will mean the plug is shorted out.
Old Feb 8, 2009 | 12:40 PM
  #39
Mike2211's Avatar
Mike2211
k so shorted out means the plug is bad is there more than can be wrong with a .000 reading or changing glow plugs is the answer... i guess i am asking is there a possibility of an electrical problem?.. cause on the ones i say i got no reading i mean no numbers came up lol i had only one plug which came up -0.00
Old Feb 8, 2009 | 01:12 PM
  #40
tjc transport
i ain't rite
nope. it sounds like you just have bad plugs.
Old Feb 8, 2009 | 07:15 PM
  #41
F350-6's Avatar
F350-6
Your truck is a 99, right? Some of the 99's did have a problem with the wiring for some of the glow plugs rubbing against a push rod and shorting out the wire. This would mean you MIGHT need a new harness under the valve cover in addition to the new glow plugs. International sells the updated harness (so this doesn't happen again) for less $$$ than Ford sells it.
I borrowed these pictures from Dan from his 99.
See the white wire touching the rod? If you move the wire, or remove the harness to inspect, the wire actually looks like this
Old Feb 9, 2009 | 01:58 PM
  #42
Mike2211's Avatar
Mike2211
I know you guys recommend Motorcraft plugs but has anyone had any experience with Delphi glow plugs?
Old Feb 9, 2009 | 02:24 PM
  #43
tjc transport
i ain't rite
yup. they are crap. if you are going to put them in, put $1500 on the side so you can have the heads pulled in 2 months time when the burn out and swell the tips, forcing you to pull the heads to get them out.
Old Feb 10, 2009 | 08:50 PM
  #44
Mike2211's Avatar
Mike2211
Anyone else have any experiences with Delphi glow plugs?
Old Feb 10, 2009 | 09:56 PM
  #45
SkySkiJason
How much are you saving? The ZD11's retail for like $11 and Autozone sold 1000's for $0.01 year before last. Forever there were folks reselling them on flebay, etc for $5-6 each.
For me, if ONE person had to remove the heads from the 'inferior' brands - I wouldn't risk it. JMHO!
Codycamp
25
Mar 2, 2015 10:02 AM
Kfanson
Apr 27, 2012 07:29 PM
mcphm519
Jan 9, 2011 08:54 PM
diesel demond
May 9, 2003 10:26 PM
Boheefus
Jul 26, 2001 04:40 AM
