Sponsored by: Real Truck
electric oil pump
Old Feb 4, 2009 | 06:52 PM
mrgoofy's Avatar
mrgoofy
electric oil pump
hi, i was told the 6.0 uses a electric oil pump is that true ?
Old Feb 4, 2009 | 07:24 PM
F350-6's Avatar
F350-6
No I don't believe it is. The 6.0 still uses a LPOP (low pressure oil pump) and HPOP (high pressure oil pump), neither of which are electric. Check further down the main forum listing for the 03-07 6.0 diesel section and those guys will answer your questions.
Old Feb 4, 2009 | 08:04 PM
dchamberlain's Avatar
dchamberlain
The 6.0L does not use an electric oil pump. It does use an electric fuel pump, which is pretty common. And an electric vacuum pump, which I thought was a bit unusual when I first saw it. Typically diesel engines used a belt driven vacuum pump, so this was new to me.
Old Feb 6, 2009 | 07:08 PM
mrgoofy's Avatar
mrgoofy
thanks for all the help ! !
DIESEL DENNIS
Sep 7, 2013 01:30 PM
z1121jack
Jan 3, 2010 09:17 AM
1954blueoval
Sep 26, 2007 07:41 PM
bio-d
May 10, 2007 10:03 AM
rickgthf
Nov 18, 2006 05:40 AM
