Question about scaning?
Old Feb 4, 2009 | 09:02 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hello all,
I am about to take my truck to school and was wondering? I am going to get it scanned to see if I can figure out why my cruise controll isnt working. My question is do I need to unplug my Dp tuner or will it be ok,
Thanks
Nick
Old Feb 4, 2009 | 09:05 AM
mueckster's Avatar
mueckster
Shouldn't be any need to disconnect the DP. I scan mine all the time with it hooked up.
Old Feb 4, 2009 | 09:21 AM
F350-6's Avatar
F350-6
You'll need to run a switch test, not just scan for codes.
Key On Engine Running (KOER) Switch (SW) Self Test
Key On Engine Running (KOER) Switch Self Test is a functional test of the PCM performed on demand with the engine running. This test is designed to set DTC(s) if the test does not detect a transition on one or more of the switches. After pressing the trigger to start the test, wait 5 seconds before running through the driver-operated controls to eliminate the chance of setting a false IVS code. The accelerator pedal must first be depressed and released to begin test, then the Parking Brake, Speed Control ON, OFF, SET, RESUME, COAST, Transmission Control or Clutch. The last to be depressed and released must be the brake pedal, which will test both the brake pressure applied (BPA) switch and the brake ON/OFF (BOO) switch.
Old Feb 4, 2009 | 09:48 AM
Pocket's Avatar
Pocket
Chris where did you find that? I've been looking for it.
Old Feb 4, 2009 | 09:53 AM
F350-6's Avatar
F350-6
I thought you just had all this stuff memorized Curtis. In the PC/ED section of the manual Section 2 Diagnostic Methods, there is a quick test description that gives you the procedure for several KOEO & KOER tests. Took me forever to find it, but that's how I located a faulty CPP on my truck.
Old Feb 4, 2009 | 11:39 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Excuse my ignorance Chris, but CPP?? Whats that lol
Old Feb 4, 2009 | 12:14 PM
F350-6's Avatar
F350-6
It's the best mod out there. All the cool kids have one, too bad you won't be able to get one in your truck.
Actually it's the Clutch Pedal Position sensor.
Old Feb 4, 2009 | 12:24 PM
STROKIN'IT7.3
Haha very nice. probably why i didnt recognize the term. thankya
Hijack over, sorry Nick
Old Feb 4, 2009 | 02:54 PM
Pocket's Avatar
Pocket
That's what I get for not reading the ENTIRE manual....
Good info, I learned something new today.
Old Feb 4, 2009 | 09:58 PM
weekendwarriorfsw32
Master of Strokes
Thanks every one for all your help. I did it and I pulled the these codes
1. P0605
2. P0603
Any guess to what these codes tell us? By the way I fixed the cruise control. All I did was clear all codes then tried it and it works? Go figure? lol
Old Feb 5, 2009 | 05:50 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
P0603 Internal Control Module KAM Error - This one is normal.
P0605 Internal Control Module ROM Error - Dont think this one is though...Havent seen it before. Maybe is nothing, hopefully someone else who knows more than me can help Nick!
Old Feb 5, 2009 | 06:35 AM
F350-6's Avatar
F350-6
The cruise issue won't throw a code until you run the switch test Nick. The 2 codes you got are PCM memory codes and won't affect how the cruise works.
Old Feb 5, 2009 | 09:39 AM
weekendwarriorfsw32
Master of Strokes
So why does the Cruise control work now?
Old Feb 5, 2009 | 09:41 AM
Powerstrokedlariat
Thats really weird Nick, any chance you replaced any fuses or anything else? I'm sure you didnt, but figured I would ask....
Old Feb 5, 2009 | 09:42 AM
F350-6's Avatar
F350-6
Because you have an intermittent failure in a switch. Mine worked on and off for a few weeks until it quit all together. You're better off running the switch test next time the cruise acts up.
