Door Panel Removal
Old Feb 4, 2009 | 07:32 AM
Bluze's Avatar
Bluze
Door Panel Removal
How do I remove the passenger side door panel to get to the speaker?
Old Feb 4, 2009 | 11:38 AM
ccecilm2's Avatar
ccecilm2
Here ya go . . .
https://www.ford-trucks.com/forums/5...l-removal.html
Old Feb 4, 2009 | 12:28 PM
Old93junk's Avatar
Old93junk
Believe me, these trucks actually have about the most simple door panels to remove.The info in the post above is correct, You can have it off on less than 5 minutes. Hardest part to re-install is getting the handle back thru.
Old Feb 4, 2009 | 04:11 PM
rambuck's Avatar
rambuck
They are simple. Thank you Ford!!! Seriously, any ******* could do it.
Old Feb 4, 2009 | 04:20 PM
nflfreak43's Avatar
nflfreak43
thats exactly what i was thinking. the hardest part is getting the door handle out and back in. other than that simple as pie. UHM chocolate pie..... what?????????? i like food!
Old Feb 5, 2009 | 06:35 PM
48' fordster's Avatar
48' fordster
The above is all correct but just thought i would mention that if you have manual crank windows you will have to take a flat head screwdriver and lightly pry the top cover off the crank. it should come off from the bigger round end, then you will have to remove the TORX screw that is inside the crank handle. I believe it is TORX 20 but im not to sure. but other then that it is the one screw in the arm rest then like 10 or so black plastic clips. Goodluck
Old Feb 5, 2009 | 06:46 PM
skaterbro's Avatar
skaterbro
Even getting the handle back through is easy. Just put your fingers through the slit where the handle comes through and pull the handle through the door panel as you hang it.
Old Feb 5, 2009 | 08:44 PM
Asylum's Avatar
Asylum
Old Feb 5, 2009 | 08:50 PM
jr32560's Avatar
jr32560
well he did not ask how to reinstall it-we will have another thread on that !!! that's when the real fun starts!
Old Feb 5, 2009 | 08:53 PM
jr32560's Avatar
jr32560
on the XLT there are a few screws in the lower panel the carpeted part! and be careful with the pop in pop out clips -they will break! take your time and you will be fine-the handle is a pain -ya have to tour the door panel to get it out -just be easy and take your time!!!!
Old Feb 5, 2009 | 09:18 PM
Old93junk's Avatar
Old93junk
When you re-install, grab the handle and pull it up as you put it thru the panel. helps to tilt the rear of the panel down as you do this. feels like you need 3 hands, but its easier than you think.
Old Feb 6, 2009 | 01:47 PM
john410312's Avatar
john410312
When reinstalling, take the inside window trim off. Straighten the clips and install last. The clips bend slightly when removing and only get worse on the reinstall if you don't take it completely off. It snaps smartly back in place if done separately.
ZFamly
Jan 29, 2011 11:20 AM
billy13
Dec 14, 2009 10:29 AM
Dough01
May 9, 2008 09:20 PM
American Muscle
1997 - 2003 F150
Dec 5, 2002 08:39 PM
buzzard
Nov 10, 2002 09:12 PM
