Pin plug removal tool
Old Feb 3, 2009 | 11:26 PM
Nod's Avatar
Nod
I am trying to remove the wire connector pins from the truck wiring harness socket on my 71 F-100 4x4 turn signal switch.I have seen the tools for sale that removes the pin ends out of the socket but can't remember where I saw them.Does anyone here know where I can find one or what size remover to buy?Thanks for any information.
"bowties in the rearview mirror"
Old Feb 4, 2009 | 12:00 AM
bmuhlbach's Avatar
bmuhlbach
I used a ball point pen tube to do mine took a few apart because there are different diameters found one that fit best and it worked great and is free.
Old Feb 4, 2009 | 08:37 AM
Freightrain's Avatar
Freightrain
Can't recall where I got mine? Napa, likely, or was it Azone? Aluminum with like 5-6 pins to pick from.
I've used a very small screwdriver(one of those "electronic" type screwdriver kits).
Old Feb 4, 2009 | 09:37 AM
rbaker6336's Avatar
rbaker6336
I always used a paper clip or a small anything that was handy
Old Feb 4, 2009 | 03:40 PM
72-F100-4V's Avatar
72-F100-4V
something else that is small and strong. Use a small allen wrench.
Old Feb 4, 2009 | 03:41 PM
73f100shortbed's Avatar
73f100shortbed
Maybe a small pick will help
Old Feb 6, 2009 | 09:22 AM
qman's Avatar
qman
I just used a small screwdriver. Works great. Don't buy the tool, save your cash.
Old Feb 6, 2009 | 03:03 PM
BobbyFord's Avatar
BobbyFord
Snap-On has a combo tool for several types of connector pins.
Old Feb 8, 2009 | 08:26 PM
Nod's Avatar
Nod
Pin Removal tool
Thanks for all the ideas everyone.I will try some to pull the pins myself with a sharp tool on my parts truck to see if I can get it that way.Worse comes to worse I will get to the parts store and buy one.Thanks again.
Old Feb 8, 2009 | 08:43 PM
Alvin in AZ's Avatar
Alvin in AZ
Anybody else use street sweeper's broom straws for stuff like this? ;)
Alvin in AZ
Old Feb 9, 2009 | 01:22 PM
68horses's Avatar
68horses
Many times if you use a screwdriver or a pick, you ruin the little catch/tab that locks in the pin when you put it back into the plastic housing. The tool is "NOT" a waste of money, although any small, sturdy tube with the inside diameter the same as the outside diameter of the pin should work fine. Also, new pins are available at most electronics stores. If you plan on re-using the same switch, do yourself a favor, and make a diagram of the plug and wire colors. If using a replacement switch, the colors often do not match the one you removed. Fun, Fun, Fun!!!
Gene
Old Feb 10, 2009 | 05:03 PM
qman's Avatar
qman
It sounded like he was trying to put in a new turn signal switch. If so then he's trying to remove the pins from the old one which is shot. That means that buying the tool is a waste of money. He's only gonna throw the pins in the trash so who cares if he ruins them.
Just make sure that when you put the new pins into the socket, you are putting them in from the back. I was holding my socket backwards when I installed the wires. Then I had to really be careful with the screwdriver removing the new pins. It wasn't a problem. Just take your time and don't rush.
DPDISXR4Ti
May 25, 2017 02:45 PM
jawmarq
Dec 31, 2016 01:32 PM
bnovak
22
Sep 25, 2016 10:40 AM
Archion
Jun 14, 2016 08:02 PM
ProStreetDriver
General Automotive Discussion
May 14, 2016 12:31 AM
