97 Explorer 5r55e question
Old Feb 3, 2009 | 09:26 PM
JF94's Avatar
JF94
I have a 1997 Explorer 4.0 SOHC with a 5r55e transmission with 135000 miles. The OD light started blinking intermitantly. While the OD light is blinking the transmission still shifts what I call normally and I can even turn the overdrive off and back on using the OD button and feel the transmision change gears and see this on the tachometer.
Went to a transmission shop today and had the codes retreived, P0741. The shop owner said this code was the TC was stuck or not locking up properly. Research on this site I found where the code means TC clutch system improper mechanical performance. Both sound close enough to me.
The shop wants to replace the electronics and soleonoids, update the valve body, replace TC and clutches, and whatever else that needs replacing, or basically rebuild the whole transmission. Cost $1500 - $1800 minimum up to $2500 to $2700 maximum.
Is this reasonable to replace all of these items for this problem? Any other advise is welcome. I will be getting a second opinion tomorrow.
JF
Old Feb 3, 2009 | 11:17 PM
85e150's Avatar
85e150
Those numbers sound familiar....
Endless discussion here:
https://www.ford-trucks.com/forums/5...lick-here.html
More, with more links, the nature and quality of which I know nothing:
Transmission 5R55E slipping, OD blinking - Ford Explorer Ranger Enthusiasts Serious Explorations
$1250, no core? Sounds too good, check out good before you jump:
Ford Transmission, Ford Transmissions, Lincoln transmission
$1579, but 5r55w, maybe he has an e in the back:
Tiger Transmission :: Ford Truck Transmissions :: Explorer Transmissions
many more if you google 'ford 5r55e transmission'
good luck....
mototrig
69
Jul 4, 2014 10:53 AM
elskeptico
Apr 21, 2012 03:14 PM
LarenceF
Aug 4, 2010 01:58 AM
fishdick
15
Apr 20, 2005 06:39 PM
